Replacing roof skin on '09 challenger? #1185323
02/24/12 11:36 AM
02/24/12 11:36 AM
K&Q va.
BIGBLOCK_KAT Offline OP
K&Q va.
I've got an '09 challenger that was a body in white car that was unfortunatly equipped with a sun roof. I want to change the roof skin to a hard top....but not sure how this panel ends or starts, other than at the front and rear window. It has two strips or rubber moulding going down the roof. I believe I need to remove these and what will I find underneath??? Spot welds or an adhesive bonding agent? Can I reuse the the mouldings when I,m done putting the new skin on?
Re: Replacing roof skin on '09 challenger? [Re: BIGBLOCK_KAT] #1185324
02/24/12 01:51 PM
02/24/12 01:51 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Here you go buddy.
Pretty sure the strips can be reused if they don't get damaged when you pull 'em. Even if they do get damaged, alot of racers are just smoothing that area out a bit, leaving the strips off off, and painting. They look good that way too.
Rich H.
Esse Quam Videri
Re: Replacing roof skin on '09 challenger? [Re: ZIPPY] #1185325
02/24/12 11:36 PM
02/24/12 11:36 PM
K&Q va.
K&Q va.
Thanks, Zippy
Re: Replacing roof skin on '09 challenger? [Re: BIGBLOCK_KAT] #1185326
02/25/12 10:30 AM
02/25/12 10:30 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
After you pull the rubber strips you will find spot welds in the ditch. 6 or 8 welds per side.
the roof overlaps the body sides in the ditch.
Gary
Re: Replacing roof skin on '09 challenger? [Re: Mr340] #1185327
02/26/12 09:55 PM
02/26/12 09:55 PM
K&Q va.
K&Q va.
Thanks, Gary I figured there would be spot welds...but 6 to 8 per side shouldn't be bad.
