1.5 vs 1.6 rockers
#1185306
02/24/12 11:17 AM
02/24/12 11:17 AM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
I'm wondering about going to a 1.6 rocker on my 426 wedge motor. It currently has iron adjustables running on the Voodoo Lunati 513" lift cam, Performer intake, 800 DP Holley, 906 heads with a little cleanup porting. Don't remember the head hasket thickness, just stock size I think. The motor has stock 10.5 to 1 flattop pistons, and I'm wondering how much lift increase I would get with 1.6 rockers. Would clearance become an issue with my current setup? If this is not fesaible, how much more cam lift could I go without getting into clearance problems? Also have Crane springs. I think they were good to 575 lift. Thanks for your opinions guys. Car is a 64 Polara with 833 OD and 3:91 gears.
Jeff Adams
64 426 Polara
Re: 1.5 vs 1.6 rockers
[Re: Ledman_70]
#1185309
02/24/12 12:34 PM
02/24/12 12:34 PM
Posts: 3,916 usa
lewtot184
usa
may depend on which iron rocker you have. i've had several sets of crane 1.5 that test to a true 1.6. i've had crane iron 1.6 that tested to a true 1.65. basically what i'm saying is you may blow money for something you already have. i'd put the money someplace else.
[Re: Ledman_70]
#1185311
02/24/12 03:17 PM
02/24/12 03:17 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
I have a similar setup with 446, Eddy heads, Speed Pro L2355F30 forged pistons, mopar roller 1.6 rockers, and the same cam you have. These pistons have valve reliefs which helps. I don't remember the piston/valve clearance but it was plenty. Mine was built for 5500 redline but have accidentally spun it to 6500. It was still pulling and no valve train issues.
BigBlock 74 Swinger
[Re: Challenger 1]
#1185312
02/24/12 03:22 PM
02/24/12 03:22 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'd put a bigger cam in it before I went with 1.6 rockers. They cause more trouble than there worth IMO.
I used to think the same thing, till someone explained something to me...
using a higher ratio rocker arm, means you're moving the mass of the pushrod and lifter less. by moving them less, you can get more lift and more duration off a cam, without having to deal with accelerating all that mass as much.
and that if you go with a 1.6, or 1.7 ratio rocker from the start, and pick your cam lift/duration knowing that you have higher rocker ratios, then you actually create a more stable valve train because you move the heavy parts, less.
**Photobucket sucks**
[Re: 70Cuda383]
#1185313
02/24/12 03:32 PM
02/24/12 03:32 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: Dodgeguy101]
#1185314
02/24/12 03:42 PM
02/24/12 03:42 PM
Posts: 16 Cincinnati Ohio
challenger11
Cincinnati Ohio
I don't buy it...put the cam with the lift you want with 1.5 rockers and your valve guides will last longer.imo
[Re: Ledman_70]
#1185315
02/24/12 04:04 PM
02/24/12 04:04 PM
Posts: 43,359 Bend,OR USA
Cab_Burge
I have no idea if the cam your running is a solid lifter or hydrualic lifter cam, if solid use a dial indicator on your retainers, both intake and exhaust and check the net lift at the retainer by rotating the motor over through one full cycle(two full crankshaft rotation for each valve) and see what your net lift is, if it is close to or less than .513 then your rockers are 1.5 or less. If it checks higher than .513 then the ratio is more ![](/ubbthreads/images/graemlins/shruggy.gif) I like and use higher ratio rockers on a lot of my motors now, they rock ![](/ubbthreads/images/graemlins/thumbs.gif) As far as wearing the valve guides out sooner, if the valve opens .500 with 1.5 rockers and you increse the cam lift to .550 then the valve travels more in the guide so wear may occur sooner IF you keep the RPM the same, if you open the valve more and make more power at a lesser RPM and shift it at a lesser RPM the valves will not wear out sooner ![](/ubbthreads/images/graemlins/grin.gif) More air equals more power ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Been there, done that ![](/ubbthreads/images/graemlins/Twocents.gif) One of the big things on changing rocker ratio is the increase opening and the increased duration at and above the effective duration of the cam ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Open it(the valves) quicker and sooner and more, especially on mild street type cams,the more power they(Mopar B-RB motors) make ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Dodgeguy101]
#1185316
02/24/12 05:08 PM
02/24/12 05:08 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
[Re: JohnRR]
#1185317
02/24/12 07:33 PM
02/24/12 07:33 PM
Ledman_70
Central Ohio
Sorry for the omission guys.... the cam is hydraulic and the rockers are stock iron Mopar. There is a lot of info here, I feel like the guys on the couch with the popcorn. This is the first high output motor I've built, and it's been a pretty good one. I just thought I could get a few more ponies fairly easily/cheaply, but maybe it's not worth the trouble. Now I'm wondering if the Crane springs will hold up to 1.6 rockers. Changing rockers is a lot easier than changing cams.
Jeff Adams
64 426 Polara
[Re: challenger11]
#1185319
02/25/12 10:31 AM
02/25/12 10:31 AM
70Cuda383
Marysville, O-H-I-O
what causes the valve to wear out the guide faster with a higher ratio rocker?
if you pay attention to your geometry and keep the rocker centered over the valve, you're not creating more side loads on the valve stem, and moving the valve up and down more from rocker arm ratio is no different than moving it up and down more from a higher cam lobe.
what are the negatives to higher ratio roller rockers, aside from quality control issues from some manufacturers, and the cost associated with them?
[Re: 70Cuda383]
#1185320
02/25/12 11:29 AM
02/25/12 11:29 AM
Challenger 1
Cincinnati, Ohio
You will have a more stabil and higher RPM capable valve train with less wear if you design the lift and duration in at the cam and not at the rockers.
[Re: Challenger 1]
#1185322
02/25/12 07:13 PM
02/25/12 07:13 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Riddle me this than, why not use 1 to 1 ratios? Did you know NASCAR engines keep getting faster and faster ratio rocker arms because they are MORE stable at RPM than a low ratio high lift cam combo. The reasoon is with the higher ratio there is LESS over all motion in the valve train and that means more stability. To keep the same valve motion with a higher ratio you use LESS pushrod and lifter lift, that is just one thing less to have to push backwards. NASCAR engines are some of the highest tech PR engines left and most of them are around 2.2 ratios, even pro-stock... are useing really high (by conventional standards) rocker ratios to help with valve train stability.
If he were talking about a 59 degree SB there would be another benifit to high RPM stability, the PR gets straightened out in relation to the lifter.
