What motor will bolt up to
#1185291
02/24/12 10:35 AM
02/24/12 10:35 AM
Posts: 2,648 GA
Boosted
GA
i have a 61 Wide block 318 push button auto car. I was wondering if this transmission can be used with other motors?
Any Ideas?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: What motor will bolt up to
[Re: RapidRobert]
#1185295
02/24/12 12:40 PM
02/24/12 12:40 PM
Posts: 2,648 GA
Boosted
GA
Well it will not work for what I am wanting to do then.. So now to plan b.... I am wanting to put a big block in the car.
2011 RAM3500
[Re: RapidRobert]
#1185297
02/24/12 12:50 PM
02/24/12 12:50 PM
Andrewh
1 bolt doesn't line up
Andrew, 1 of which bolts will not line up
one bolt hole in the transmission doesn't line up with the block. driverside near the top as I recall.
op, yeah, you have to change transmissions to use a BB.
There are a couple of choices find another cable shifted BB trans(see cores for them on the classifieds here) use a later model and a later model floor shifter.
I think it is agreed that the imperial services adapter is crap.
BUT I did notice the later truck/ van's late 90's and up seem to use some sort of cable to shift their transmissions.
When I was stealing parts to do the kick down parts for my magnum swap, I noticed that there were cables instead of linkages doing the shifting for those vans. might be a way to adapt that to the pushbutton stuff, but someone would have to measure the throws vs the movment from the buttons.
