Re: freeze plugs
[Re: CIB]
#1185013
02/23/12 08:50 PM
02/23/12 08:50 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
1) remove old plug 2) install new plug
Does that help?
Are you trying to do the block plugs with the engine in the car? If so, drop the exhaust and starter then go from underneath the car.
Re: freeze plugs
[Re: CIB]
#1185015
02/23/12 09:32 PM
02/23/12 09:32 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Look up some videos on YouTube. Usually folks tap up against one edge with a screwdriver to flip it over and then grab it with pliers. Big socket or small seal driver to get the new one in.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: freeze plugs
[Re: Secret Chimp]
#1185016
02/23/12 11:09 PM
02/23/12 11:09 PM
Posts: 1,443 Maryland
Dads426
Maryland
The rear plugs can be difficult to get out because the cylinder wall is right behind it, so it won't turn when you hit one side. It usually falls in the water jacket and you have to fish it out with a magnet, crush two sides, then use channel locks or vise grips to pull it out.
If installing in the car, be sure you can get a straight shot at the plug with a socket & extension or it will be very hard to press in squarely. Usually the K-Frame is in the way of the front plugs.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
Re: freeze plugs
[Re: CIB]
#1185020
02/24/12 09:25 AM
02/24/12 09:25 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
long term permanent repair, or do you plan on any major engine work anytime soon?
if you're going to be pulling the engine out anytime in the near future, but just want to get it TO that point, then you might have luck with one of those rubber plugs that seal up as you tighten the center bolt.
they're really easy to do on the engine stand. really a pain in the butt in the engine bay!
I use a large blunt chisel, hit on one side till the plug rotates in the bore, then grab it and yank it out. drive the new one in squarely with a large socket. I put a light layer of RTV around the edge of the plug, incase there's imperfections in the bore for the plug, but it seems that most of it just wipes off as it slides in
**Photobucket sucks**
