Steering wheel resto paint questions #1184381
02/22/12 10:14 PM
02/22/12 10:14 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'm restoring a 68-69 A/B-body black three spoke sport steering wheel (the type that looks like the woodgrain wheels only black). I am to the point where I am ready to paint and would like to know what paints for both the rim and the spokes is best for replicating the original colors and amount of gloss. Also, should the black on the rim be some sort of textured paint to simulate woodgrain?
Re: Steering wheel resto paint questions [Re: 1970RT] #1184382
02/23/12 10:34 AM
02/23/12 10:34 AM
SE Pa.
LimeliteAero Offline
SE Pa.
there should not be any texture in a colored wheel for 68-69, that was the 70 wheel.
member Pntastar69 recently converted his "wood" wheel into a Black wheel with amazing results. maybe he'll chime in with some input.
Re: Steering wheel resto paint questions [Re: LimeliteAero] #1184383
02/23/12 12:45 PM
02/23/12 12:45 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Was the black wheel available in 70? I was under the impression the black wheel was 68-69 only. I can't say for sure what year the wheel is from but although it was worn smooth all the way around the rim there is still some texture visible where the plastic joins the spokes.
Re: Steering wheel resto paint questions [Re: 1970RT] #1184384
02/23/12 12:52 PM
02/23/12 12:52 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The textured & colored steering wheels that looked similar to the wood-grained "sport" wheel were STANDARD on '69 Barracudas ONLY & came in Green, Tan, Blue, Red, & Black.
Re: Steering wheel resto paint questions [Re: 6bblgt] #1184385
02/23/12 12:57 PM
02/23/12 12:57 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
The dealer data book calls it "leather like" however I would describe as pebble grain. The texture is very similar to the finish on the 69-70 B body rallye dash. I have one that has split at the top in the same way as the woodgrain wheels do. I have checked with several wheel restorers but they cannot match the texture. Will try to post a pic later today.
Re: Steering wheel resto paint questions [Re: 6bblgt] #1184386
02/23/12 12:57 PM
02/23/12 12:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
GREEN
Re: Steering wheel resto paint questions [Re: moparfan53] #1184387
02/23/12 01:30 PM
02/23/12 01:30 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Yes, that is how I would describe it too. I'm not sure what to use for paint to try and simulate the grain or if I should just paint it gloss or semi gloss black. As far as the spokes are concerned, I was thinking of using light argent like that which is used on rally wheels.
Re: Steering wheel resto paint questions [Re: 1970RT] #1184388
02/23/12 10:32 PM
02/23/12 10:32 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here are some pics showing the shape and texture of the rim. I have never restored a wheel however here is my 2 cents. Your idea for the spokes sounds good. The rim texture would be hard to duplicate so probably your semi-gloss paint idea is best. Wish I had some solid help/ideas for you.
Re: Steering wheel resto paint questions [Re: moparfan53] #1184389
02/24/12 01:12 AM
02/24/12 01:12 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Thanks for the pics.
Re: Steering wheel resto paint questions [Re: 1970RT] #1184390
02/24/12 11:15 PM
02/24/12 11:15 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
Duplicating the pebblegrain would be nearly impossible to do as a restoration. Your best bet is to just make it smooth. To refinish the spokes, get PPG "Liquid Metal". It is the closest thing you'll find to the satin chrome finish.
Re: Steering wheel resto paint questions [Re: plumbeeper] #1184391
02/28/12 02:32 AM
02/28/12 02:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I'm pretty sure the spokes are either stainless or satin chrome, not originally painted. Be sure to try polishing the finish back to original look before resorting to paint. Mine looks great with just polishing.
In the case of chrome plating, you can make light rust disappear with extra polishing. Pick one small area, hand polish with chrome polish for about 5 minutes, and watch carefully if the rust is decreasing. If so, you might be able to get all the rust off. It's as though some of the iron molecules got on top of the chrome, but they can be wiped off with extra polishing. Polishing rust off chrome will take some time and elbow grease, but it works!
I got all the rust off my gear shift lever by polishing. Took maybe 1 hour of work. This didn't work for my exhaust tips - they were too far gone and pitted.
