71-74 Charger Hood Release Cable Routing #1183918
02/22/12 10:24 AM
02/22/12 10:24 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I need some information and/or pictures of how the remote hood release cable is properly routed from the dash through firewall/radiator support to the hood latch assembly. I can make a guess but I would like to do it right the first time.
Car is a 1973 Charger. I am guessing this would be the same for 71-74 Chargers/B-bodies?
Any help is appreciated!
Re: 71-74 Charger Hood Release Cable Routing [Re: cjskotni] #1183919
02/22/12 10:54 AM
02/22/12 10:54 AM
IMGTX Offline
IMGTX  Offline
I just happened to have posted these pics a few months ago so your in luck.
Ignore the fact my release cable looks wrinkled. I had to repair it.
Re: 71-74 Charger Hood Release Cable Routing [Re: IMGTX] #1183920
02/22/12 03:06 PM
02/22/12 03:06 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Holy documentation, Batman! Thanks for the pics...I was thinking aroudn thes elines but when you have the entire interior out of the car for 5 years and you are trying to put everything back together, it helps to know which firewall hole to rpute that sucker through!
What car/year are your pics from? I do not have that shield in you 2nd to last pic and my hood latch support has no provisions for one that I can see...
Re: 71-74 Charger Hood Release Cable Routing [Re: cjskotni] #1183921
02/22/12 03:32 PM
02/22/12 03:32 PM
IMGTX Offline
IMGTX  Offline
It's from a 74 RR/Satellite.
They may not use the shield on the Chargers since there is a big tooth in the middle of the bumper to protect it from road debris but the cable is run the same.
