Re: Too much cam for...
[Re: moparjimm]
#1183710
02/22/12 03:01 AM
02/22/12 03:01 AM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi you have opened a can of worms !!! what is the piston to deck heigth ? you will need srings to match the cam lift ! you will need to cut valve guides down app .125" why run a .040" thick gasket? .020" steel should work and save some compression ? piston to alve clearance must be checked ! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: moparjimm]
#1183711
02/22/12 03:03 AM
02/22/12 03:03 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
whats the rest of your combination??
I am truckless..
[Re: 340SHORTY]
#1183712
02/23/12 01:02 PM
02/23/12 01:02 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
Without getting into all that block height/clay the pistons stuff, I built a 426 wedge 6 years ago using the stock 10.5 to 1 flat top pistons, the Voodoo 513" lift cam, Crane springs. Stock gaskets, I don't remember the thickness. I didn't clay anything, just spun the motor over. The engine has over 6k on it now and still screams. I know everything should be checked, but I was told the cam was ok with stock pistons and my block had never been decked. The cam pulls great from idle to about 5200 rpm, which is pretty much where my motor is about done making power. I have stock 906 heads with a little port clean up, Edlebrock RPM intake, ceramic headers, and a 800DP Holley. Never had any clearance issues. I'm running an 833 OD and 3:91 gears. The car (64 Polara) gets sideways easily in 1st gear and sometimes 2nd, too, and cruises 65 at about 2200 rpm.
Jeff Adams
64 426 Polara
[Re: Mr.Yuck]
#1183714
02/23/12 10:45 PM
02/23/12 10:45 PM
Posts: 41 Tucson, AZ
moparjimm
Tucson, AZ
Thanks so far. The car will be running a tunnel ram with 2 600's, 1 7/8" fender well headers, 24-2800 stall and 4.10 or 4.30 gears, 29-31" tires. This car is basically just for show, sorry guys, no real racing with this one. The heads have 509" springs already on them. Jim 70 RR 440+6(V code), 69 Coronet(440), 2 66 chargers(1 is a clone stock car), 2 67 Chargers, and a 64 Belvedere(drag car) ![](/ubbthreads/images/graemlins/coool.gif)
