mounting alternator with a motor plate #1183665
02/21/12 09:11 PM
02/21/12 09:11 PM
Annapolis, Missouri USA
CIB Offline OP
CIB  Offline OP
Have a 440 supported by a motor plate instead of motor mounts in a race car. How do you you mount an alternator when it hits the motor plate?
Re: mounting alternator with a motor plate [Re: CIB] #1183666
02/21/12 09:17 PM
02/21/12 09:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
AndyF makes a kit for his plate and Denso alternator. I use a different Denso alternator so I just use a stud and nut set-up.
Gus
64 Plymouth Savoy
Dana 60
Re: mounting alternator with a motor plate [Re: fourgearsavoy] #1183667
02/21/12 09:24 PM
02/21/12 09:24 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i have one of andy f older plate's and had to notch it.
Re: mounting alternator with a motor plate [Re: CIB] #1183668
02/21/12 09:40 PM
02/21/12 09:40 PM
AndyF Offline
AndyF  Offline
This is the kit that I sell. Part number AR207. But it only works with the Powermaster alternator, ATI damper and the short DMI pulley. Typically guys have to fabricate a solution because they are using different dampers, pulleys, alternators, etc.
Re: mounting alternator with a motor plate [Re: AndyF] #1183669
02/21/12 09:45 PM
02/21/12 09:45 PM
CIB Offline OP
CIB  Offline OP
Thanks for all the replys.
Re: mounting alternator with a motor plate [Re: CIB] #1183670
02/21/12 10:40 PM
02/21/12 10:40 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I welded a boss to my water pump. Then cut a radiused groove in the plate to adjust it.
Doug
Re: mounting alternator with a motor plate [Re: CIB] #1183671
02/21/12 11:08 PM
02/21/12 11:08 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Mine....
