Fan Clutch shaft length? #1183046
02/20/12 08:42 PM
02/20/12 08:42 PM
6T9RR Offline OP
6T9RR  Offline OP
I bought a 5 blade clutch fan years ago for my 69 Road Runner and the shop that is installing it showed me that it won't fit. They have an old 7 blade clutch fan with a shorter shaft on the clutch and it fits fine. I need to find and purchase a new one if I can, does anyone know where I can get one? The part number that is on the clutch of the 7 blade clutch fan with the shorter shaft is 2658456. (FYI - The part number on the 5 blade clutch fan with the longer shaft is 4095704.)
Thanks, Paul
Re: Fan Clutch shaft length? [Re: 6T9RR] #1183047
02/20/12 10:27 PM
02/20/12 10:27 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
1989 jag xj6 napa # tem 261306
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Fan Clutch shaft length? [Re: 6T9RR] #1183048
02/20/12 11:16 PM
02/20/12 11:16 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
Get the Hayden 1705... closest you will find to the 070 dimensions. It's only about 20 bucks.
[oo]======[oo]
Re: Fan Clutch shaft length? [Re: Scatransit] #1183049
02/21/12 12:18 AM
02/21/12 12:18 AM
6T9RR Offline OP
6T9RR  Offline OP
Thank you both very much!
Re: Fan Clutch shaft length? [Re: 6T9RR] #1183050
02/21/12 05:43 PM
02/21/12 05:43 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..fan clutches operate at 70% of the water pump speed,are heavy
and some engines will heat up at idle
.. flex fans are light and keep the engine cool when idling,but some don't like them.
