Bodywork-inner roof treatment
#1182607
02/20/12 09:58 AM
02/20/12 09:58 AM
Posts: 1,896 New England
Q5_Ed
New England
What would be the best method to cleanup the inner roof and structure of a 69 b-body? Looking for sanding, cleaning, and preferred paint/treatment methods.
Thanks in advance...
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: Bodywork-inner roof treatment
[Re: elitecustombody]
#1182609
02/20/12 03:25 PM
02/20/12 03:25 PM
Q5_Ed
New England
I have used a wire wheel on a grinder for the structural braces, scraped the sheet metal inner roof with a wide razor to get all the glue off. Would you use a DA for sanding? What grit? Very light surface rust remaining.
Also why do you prefer epoxy over etch primer?
I was also debating Zero Rust from rest rick?
Ed
[Re: Q5_Ed]
#1182610
02/20/12 04:07 PM
02/20/12 04:07 PM
OLD318
My preference is to sand/lightly grind the underside of the roof. This will take some time. Do not press hard on the roof skin from underneath. You're going to be working upside down so to speak so make sure you wear eye protection /dust mask/respirator. Then you can use either wash/ epoxy or zero rust etc... The wash/etch primer requires another primer on top of it before painting. Like PPG K36 which has to be sanded before painting. If you use epoxy primer (like PPG DPLF) you can spray 2 coats of epoxy,wait a day and paint right over it. no sanding required.. Just my Best of luck to you
[Re: OLD318]
#1182611
02/20/12 05:34 PM
02/20/12 05:34 PM
Q5_Ed
New England
Thanks for the feedback. I certainly want to avoid sanding between painting. Can you etch or epoxy prime, then paint it months later? Or can you etch prime now, epoxy over it later in the process, , then top coat way down the road?
Don't know my way around paint much yet. But I plan to do work on the inner roof, underside, and possibly engine compartment, before turning it over to a pro to do the finish sheet metal work. Expect time gaps between work, and don't want to have any compatibility issues when they do finish work.
Ed
[Re: Q5_Ed]
#1182612
02/21/12 02:55 AM
02/21/12 02:55 AM
Posts: 49 alaska
69 mayflower
alaska
I used a combination of media blasting and wire wheel and da sander to get mine clean and rustfree.I then put two coats of dip gray zero rust from Resto Rick.It is my understanding that once it is fully cured,which is very important,you can topcoat it with your color coat.I am going to leave mine with the zero rust as it will all be covered by the headliner.I am very impressed with the way the zero rust sprays and cures to a very tough coating.I also got one of those wand attachments and sprayed it in all the roof cavities.Also the complete underside of the car.
1969 Plymouth Sport Satellite 383
1990 Dodge W150 plowtruck 318
2012 Dodge Ram 1500 4WD 5.7 HEMI
2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI
MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
[Re: Q5_Ed]
#1182613
02/21/12 03:52 PM
02/21/12 03:52 PM
OLD318
I can't speak for other paint systems (DuPont, Sikkens, etc) With PPG Deltron, your wet-on-wet opportunity is about a week. For example, With the DPLF epoxy primer, you can spray it one day...and within a week you can topcoat it with either a urethane primer for blocking or paint, if the panel is straight. WITHOUT having to scuff or sand it. It's a big time savings.
Anytime after a week, you are going to have to scuff the surface (scothbrite) first, wipe it off, tack it off and then you are required to spray 1 coat of epoxy, then wait an hour and then topcoat etc..
The p-sheet (tech bulletin) for the paint product your spraying should provide you with this information.
This is PPG's Deltron line of paint/primer etc... It is VERY expensive but I love it... Other's on here can chime in with their paint systems...
If you've never sprayed a car before, I recommend taking a collision repair/paint course at your local community college if it is available.
Just my
Best of luck to you
[Re: Q5_Ed]
#1182615
02/22/12 10:21 AM
02/22/12 10:21 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Ed
I believe You dont want to put epoxy primer over etch primer
