B engine with A engine radiator
#1182392
02/19/12 11:29 PM
02/19/12 11:29 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
This has to have been done before, but oddly I havent had to cross this in the past. All my big block cars were originally big block cars.
MY 65 coronet had a poly engine. I now have a 383 in the engine bay, and have a 440 Source water pump, drivers side hose mount.
I am not too concerned about the top hose, but the lower one, well, its right up against the filter. I dont even think I could get a flex hose on it. I will change radiators if I have to, but I am thinking about running the shorter oil filter then trying the flex hose.
Any other solutions besides the obvious radiator replacement?
Re: B engine with A engine radiator
[Re: NTOLERANCE]
#1182396
02/20/12 11:07 AM
02/20/12 11:07 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I had the same issue on my '65 Coronet when I went to a big block. I had the radiator re-cored and the lower hose connection moved. It worked perfectly. As luck would have it, I then found an original 426 radiator and installed it. Still have the first one on a shelf.
This is the land of the free
because of the brave
[Re: NTOLERANCE]
#1182397
02/20/12 03:33 PM
02/20/12 03:33 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
It slips me right now, but the inlet/outlet sizing varies somewhat per Small-Block to Big Block radiator application. True story, a friend of mine tried a freshly re-cored 26" A/C Small-Block radiator in a slightly warmed-up over stock street 383. Not an issue until the warmest of summer days when overheating was inherent. Can't recall all the fan/shroud/t-stat/pump changes he fussed with but something was deficient in the chain and I don't think he ever solved the issue. The small-block radiator might suite you well, but it could also be a lot of effort/money invested in something that results in less than satisfactory performance and grief down the road. As the saying goes, pay me now or pay me later...
[Re: NTOLERANCE]
#1182399
02/20/12 09:16 PM
02/20/12 09:16 PM
NTOLERANCE
Madison Wi
Pic, its a bit tight in there.
[Re: rbstroker]
#1182401
02/20/12 10:04 PM
02/20/12 10:04 PM
NTOLERANCE
Madison Wi
The hhr fan is attached to the radiator.
