Re: Carb choices???
[Re: rioval]
#1182318
02/19/12 10:23 PM
02/19/12 10:23 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi you need a heaver pump shot from what you describe! a 750 vac holley will blow that edey into the weeds !
Re: Carb choices???
[Re: rioval]
#1182319
02/19/12 10:34 PM
02/19/12 10:34 PM
RapidRobert
Yes need an adequate pump shot; amt/duration. Is your initial in the ballpark along w pri jetting/float levels. No vac leaks?
Re: Carb choices???
[Re: rioval]
#1182325
02/20/12 10:12 PM
02/20/12 10:12 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks for the feedback! If I go with a new carb, what CFM, 650 or 750? Mechanical or vacumn? My motor, 383, is stock but I have intentions of a slight upgrade like mopar performance camshaft 484 lift and aftermarket cast iron heads.
the 484 likes good compression, headers, 3000+ stall and 3.91+ to run right. If you go w/ a holley make sure you use like a 4.5 PV or close to it. Those cams do not pull great vaccuum.
