SQUIRT BOTTLE #1182001
02/19/12 11:54 AM
02/19/12 11:54 AM
pgh pa
captaindodge Offline OP
pgh pa
Any ideas for a primer/squirt bottle to get gas in the carb similar to what the Top Fuel guys use?
Re: SQUIRT BOTTLE [Re: captaindodge] #1182002
02/19/12 12:24 PM
02/19/12 12:24 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
contact lens solution bottle?
Re: SQUIRT BOTTLE [Re: 65rbdodge] #1182003
02/19/12 12:37 PM
02/19/12 12:37 PM
scratchnfotraction Offline
I use a dawn dish soap bottle to prim carbs with and with starting primeing down the throt of carbs as they are crank over.
I had a drink bottle with a sippy straw that worked good also.
Re: SQUIRT BOTTLE [Re: scratchnfotraction] #1182004
02/19/12 12:40 PM
02/19/12 12:40 PM
pgh pa
pgh pa
thanks good idea
Re: SQUIRT BOTTLE [Re: captaindodge] #1182005
02/19/12 02:34 PM
02/19/12 02:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Mustard or ketchup squirt bottle from the dollar store.
Re: SQUIRT BOTTLE [Re: captaindodge] #1182006
02/19/12 04:54 PM
02/19/12 04:54 PM
is the gas evaporating out of the bowl to where you have to prime it every time?
Re: SQUIRT BOTTLE [Re: RapidRobert] #1182007
02/19/12 05:50 PM
02/19/12 05:50 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
Look on e bay or hobby shop for a r/c gas bottle, they work well.
Re: SQUIRT BOTTLE [Re: RapidRobert] #1182008
02/19/12 07:27 PM
02/19/12 07:27 PM
pgh pa
pgh pa
If not re-started within 12 hours it needs primed. I've owned this car 39 years. Same AVS carb. Works perfect after it starts. If I crank it to fill bowls the battery nearly dies. Prime it and it starts immediately. This is a survivor engine. Heads never off. 69 440 Magnum
Re: SQUIRT BOTTLE [Re: captaindodge] #1182009
02/19/12 10:15 PM
02/19/12 10:15 PM
I'd pull the air cleaner & see if there's an AP squirt before you crank it. If not & it's evaporating that fast I wonder if the heat riser is on all the time & heat soak is evaporating the bowl. If you fill the bowl does the AP kick out a good squirt
Re: SQUIRT BOTTLE [Re: RapidRobert] #1182010
02/19/12 11:26 PM
02/19/12 11:26 PM
pgh pa
pgh pa
R.R. How many AP shots does it take to equal .5 ounce because thats what it takes to get it fired up. I would guess 15 shots. I know it is not heat soak because I have got the engine started then shut it off cold and it still will not start the next day.
Re: SQUIRT BOTTLE [Re: captaindodge] #1182011
02/19/12 11:32 PM
02/19/12 11:32 PM
I bet it has a cracked main body on the carb. if it lost prime in 12 hrs and only needs .5 to restart it.
i have had to epoxy many q-jets for leaky fuel/jet wells
thermobog will do the same thing when the plastic main body is cracked.
does the oil smell like gas? are you sure its not dumping it down the intake and washing the cyls?
how do the plugs look?
got a mini starter and new battery yet?..just kidding
Re: SQUIRT BOTTLE [Re: scratchnfotraction] #1182012
02/20/12 08:40 AM
02/20/12 08:40 AM
pgh pa
pgh pa
No cracks and I must have my "Bam-Bam-Bam-Bam" starter. It shouts Mopar just like H-pipe and hemi mufflers. From what I read on Moparts this is a common problem although it's good for anti-theft.
Re: SQUIRT BOTTLE [Re: captaindodge] #1182013
02/20/12 11:31 AM
02/20/12 11:31 AM
Not sure what's going on cuz the symptoms ain't pointing directly to anything but we'll stay w it till we figure it out
