Powder coat leaf springs: Yes or no?
#1181546
02/18/12 02:32 PM
02/18/12 02:32 PM
Posts: 339 California
moparbroz
California
Will excessive heat affect the metal?
Hebrews 11:1
Re: Powder coat leaf springs: Yes or no?
[Re: moparbroz]
#1181547
02/18/12 02:36 PM
02/18/12 02:36 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
where does any excessive hear come from?
I am truckless..
[Re: zrxkawboy]
#1181549
02/18/12 03:27 PM
02/18/12 03:27 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I'm guessing he means from the baking/curing process.
It's only 300-350 degree F
[Re: zrxkawboy]
#1181550
02/18/12 06:16 PM
02/18/12 06:16 PM
moparbroz
California
Yep. Heat from the powder coating method.
Hebrews 11:1
[Re: 71birdJ68]
#1181552
02/18/12 06:58 PM
02/18/12 06:58 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Sooner or later you'll regret power coting.
Yes, power cots are troublesome, something as simple as a cot doesn't need to be powered!
[Re: Pacnorthcuda]
#1181554
02/19/12 12:41 AM
02/19/12 12:41 AM
moparbroz
California
And you say this because......? Quote:
Hebrews 11:1
[Re: moparbroz]
#1181555
02/19/12 05:07 AM
02/19/12 05:07 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
a spring flexs to work.. Powdercoat doesnt..
I am truckless..
[Re: TheBlueBeast]
#1181559
02/19/12 10:57 AM
02/19/12 10:57 AM
RapidRobert
My Landrum circle track rear springs are a nice baby blue. They still look good after 1 season
[Re: moparbroz]
#1181561
02/19/12 01:20 PM
02/19/12 01:20 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
Powder coat cures at different temperatures depending on the material and your processor. The facility I use cures at 450 degrees, temperatures this high can change the temper of the spring and for this reason I chose not to powder coat my original 1970 springs, figuring they were not curved based on a reduced temper. My main concern with this would be ride height, not failure. I did recently read an article that talked about some new systems that cure at as low as 250 degrees, well within a safe range to not change material temper
New springs curved based on the final temper should be fine (i.e a manufacturer that designed their spring based on body weight and ride height, think of this as a system), but I don't think this is what your talking about.
The other concern I would have would be sticking. Powder coat is basically melted plastic and I'm unsure if it were completely coated that it wouldn't cause the springs to stick. Assuming you still use the zinc inserts and plastic slides it really becomes an issue with how well they react with the powder coat. Unless you plan to pre assemble and mask the contact areas to remain bare, eliminating all these issues.
Best of luck with your decision, would love hear detail, see pictures, and hear your impression should you decide to go this route.
[Re: AAR#2]
#1181562
02/19/12 02:13 PM
02/19/12 02:13 PM
moparbroz
California
Great feedback. Thank you. I will follow up with pics and results/issues. Worst case scenario? Buy a set of new springs! Quote:
Hebrews 11:1
