Re: My new Torque plate from Performance only! [Re: dartman366] #1180113
02/20/12 02:14 AM
02/20/12 02:14 AM
FL
74-440Charger Offline
FL
Not familiar with his shop, he's about 12 hours south from me. But I need to give him a call.
Re: My new Torque plate from Performance only! [Re: 74-440Charger] #1180114
02/20/12 02:43 AM
02/20/12 02:43 AM
Delray beach, Florida
P
Performance Only Offline
P
you must be in the western panhandle to be 12 hours away. i think i could almost be in Virginia in 12 hours from here. let me know if there's anything i can help you with.
machine shop owner and engine builder
Re: My new Torque plate from Performance only! [Re: Performance Only] #1180115
02/20/12 03:34 AM
02/20/12 03:34 AM
FL
FL
Yes, Panama City. I have a 440 that needs to be redone for strong street strip duty, going through the body now. Will give you a call when it's time for the motor.
Re: My new Torque plate from Performance only! [Re: 74-440Charger] #1180116
02/20/12 11:16 AM
02/20/12 11:16 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
you won't be sorry..
Re: My new Torque plate from Performance only! [Re: dartman366] #1180117
02/20/12 12:48 PM
02/20/12 12:48 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Does it make any difference if the plate is aluminum and you are using iron heads?
Re: My new Torque plate from Performance only! [Re: TrWaters] #1180118
02/20/12 02:28 PM
02/20/12 02:28 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I don't think it makes much difference but the aluminum one is way easier on the back!
Re: My new Torque plate from Performance only! [Re: Dodgem] #1180119
02/20/12 02:47 PM
02/20/12 02:47 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Just as a note way back in time (1992) my machinist (new to me then) talked me into going from .040 over to .060 over so we could smooth out my bores from not having a torque plate. He had one so I went in after the motor was bored and he showed me how nice and round the cylinders were. then he bolted on the torque plate and he showed me how much that pushed the cylinders out of round! Then showed me how they now honed out straight. he too wants the head gasket you will be using nice I went bigger bore head gasket two years ago so they are the ones 1105 I'll be using so I have used ones to use!
So the only change I made was the + 4 cubic inches and we went up .5 in compression 10 to 1s to 10.5 (or standard 10 to 1's to 10.5 six barrel pistons) same cam heads and all and it ran at least .55 better all the time so I was sold! So if you give .15 to .2 to the little raise in compression and cubes the .4 to .35 was from better sealing bores!!!
Since Dan's looked so pretty and I could not talk him into boring his plate out from 4.380 to the 4.5+ I need now I bit the bullet for a real nice piece!!
