Chassis dyno .. ? #1180027
02/17/12 05:53 PM
02/17/12 05:53 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
A/F mixture , a sensor in the headpipe vs. a tailpipe sniffer?
I'm think a sensor in the headpipe will give accurate readings vs. one in the tailpipe?
Re: Chassis dyno .. ? [Re: JohnRR] #1180028
02/17/12 06:59 PM
02/17/12 06:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've found the difference is very little between the two if both are accurate.
My in-the-car display reading from an 02 in the collector is within .1 a/f of the chassis dyno sniffer... but that is only for WOT
Rich H.
Esse Quam Videri
Re: Chassis dyno .. ? [Re: ZIPPY] #1180029
02/17/12 07:12 PM
02/17/12 07:12 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
sniffer works great as long as you have no exhaust leaks
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: Chassis dyno .. ? [Re: JohnRR] #1180030
02/17/12 09:21 PM
02/17/12 09:21 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
Putting a bung in the headpipe is the best option. You have to weld one in though. You can plug it with a short bolt after dyno.
Re: Chassis dyno .. ? [Re: 1970sixpak] #1180031
02/17/12 11:57 PM
02/17/12 11:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I suggest you also "read" the spark plugs.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Chassis dyno .. ? [Re: hemi-itis] #1180032
02/18/12 02:09 PM
02/18/12 02:09 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Thanks guys , this is for another board member , he called a local place to get his carb dialed in and they said they have a tail pipe sniffer , should be good enough for what he needs .
