Best way to polish trim already on a car?? #1179989
02/17/12 04:40 PM
02/17/12 04:40 PM
Colorado
CuriousYella70 Offline OP
Colorado
The shine on the window trim and drip rail trim on my Duster is starting to ware off and look a little lack luster. What's the best way to polish the trim? Is it possible to do while on the car and if so, how and what kind of polish? If I have to take it off, I will but naturally - it's my least preference to do!
Thanks for the help all
Re: Best way to polish trim already on a car?? [Re: CuriousYella70] #1179990
02/17/12 06:43 PM
02/17/12 06:43 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Mothers Billet polish with a microfiber towel works the best IMO. According to my polisher guy there is no polishing compound that will work on stainless steel, but the Billet polish seems to shine it up pretty nicely. It's not cheap, but it works.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Best way to polish trim already on a car?? [Re: DconD100] #1179991
02/17/12 07:27 PM
02/17/12 07:27 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Die grinder with buffing wheel attachment.
Use household light dimmer extension cord to vary the RPM. Then use blue painters tape and newpaper to mask off surrounding area to compound doesn't spatter everywere.
MUST use full eye protection. Goggles fully enclosed.
Re: Best way to polish trim already on a car?? [Re: autoxcuda] #1179992
02/17/12 07:45 PM
02/17/12 07:45 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I usually polish the trim on the car before I remove it with an industrial die grinder with a 10" bonnet bolted to it Masking tape is the key for one with good paint edge that with foil tape. Works great & saves money
