How do you runa 6.1 L hemi without the A/C compressor?
#1179680
02/17/12 12:51 AM
02/17/12 12:51 AM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
I am doing a 6.1 swap and may want to leave the A/C compressor off. Is there a bracket with pulley that I need to put in its place for the belt routing or just run a shorter belt and bypass that area? Thanks -C ![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: How do you runa 6.1 L hemi without the A/C compressor?
[Re: ramman5600]
#1179683
02/18/12 06:38 PM
02/18/12 06:38 PM
Posts: 33 Calgary, Alberta
Turbo392
Calgary, Alberta
I have a Mopar A/C delete pulley on my truck right now, but it is for the truck front cover. I imagine there is a Mopar pulley for the car cover as well, or maybe this one works on both?
2003 Dodge Ram 1500
Turbo / Meth Injected 6.4L Hemi (392)
[Re: Turbo392]
#1179684
02/18/12 06:40 PM
02/18/12 06:40 PM
ramman5600
Michigan, USA
In the link to Bouchillon it looks like it just gets bypassed on the car cover - I may just install the A/C compressor and not wire it up.
-C
[Re: ramman5600]
#1179685
02/18/12 06:53 PM
02/18/12 06:53 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
just run a shorter belt. leave it off. measure what length belt you need and there you go.
on the pictures on that web sight the last one shows you what it will look like...with or without the power steering pump
if You Like Gremlinsteve. Gremlinsteve Likes You.
