340 Trans to Engine Block Supports #1179267
02/16/12 10:15 AM
02/16/12 10:15 AM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
I have a June 71 build 340 Auto Challenger and do not have the two supports that go between the trans and engine. Should I have these supports?
Re: 340 Trans to Engine Block Supports [Re: JAK] #1179268
02/16/12 02:32 PM
02/16/12 02:32 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
FWIW my 71 Road Runner 340/Auto with a build date of 7/17/71 has them.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 340 Trans to Engine Block Supports [Re: JAK] #1179269
02/16/12 08:02 PM
02/16/12 08:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes you should have them , many people remove them the first time you have to do something under there that requires them to be removed and they end up under the bench or in the scrap bin . It's been a long time but I seem to remember having to remove one to change a starter in a smallblock A body, it didn't go back ...
Re: 340 Trans to Engine Block Supports [Re: JohnRR] #1179270
02/16/12 11:01 PM
02/16/12 11:01 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
That is what I was thinking.
Re: 340 Trans to Engine Block Supports [Re: JAK] #1179271
02/17/12 11:35 PM
02/17/12 11:35 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yes, it should have them, and on a 340, they should be the same parts as on any 318. 360 cars are not so clean cut. One side of the 360 is the same as 318/340 cars, but the other side (at least by 1974) changed and is very similar, but about 1" longer than 318-340 cars
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
