Re: Need photo 70 E-Body Backside of Dash Please.
[Re: screamindriver]
#117901
11/08/08 02:04 PM
11/08/08 02:04 PM
btw, my drawing that I posted above is wrong. I switched the red and tellow wires in the drawing when I was writing them down. So it should go Blk w/yel goes to yellow and then to the yellow on that relay.
the red goes to the red and then to the blak at the relay.
thats what you get work upside down in a cramped area.
in any event, I soldered in a 1n4005 diode into that black and yellow harness that used to go to the relay and the headlight warning works great
[Re: ebodyseast]
#117907
12/20/08 12:14 PM
12/20/08 12:14 PM
Posts: 4,165 Florida
cataclysm80
the optional standard dash map light & switch panel light bulb
That looks a little confusing ebodyseast. Could you explain that a little better?
The map light is on the bottom edge of dash frame by passengers left foot. The title lamp lights up the switch panel. The ignition lamp is the one in the steering column.
Just from memory, I was thinking all 3 came with the optional A01 light package, which was available with OR without rallye dash.
I didn't look at the diagram for this, but I'm thinking the map light has steady power with switched ground (typically yellow wires), the title lamp has steady ground with switched power (typically orange wires), and the ignition lamp is hooked up with the time delay somehow.
Seat belt lamp would be time delay too.
Tav
P.S. As a side note, the map light location moves from the dash frame to some plastic trim on AC cars, but I don't think this affects the wiring harness in any way.
Also the ignition lamp changed between 70 & 71. I'm not sure if that affected the wiring connector or not.
[Re: Snoopy]
#117912
01/05/09 11:44 PM
01/05/09 11:44 PM
Posts: 1,822 Colorado
denfireguy
Colorado
How about this one. Item "J". It looks like it might be taped down to the wiring harness. Maybe someone can take a look on an unmolested car?
I just got to my dash. Mine is an unmolested 73 and the timer is wrapped into the harness upside down on the bundle going to the fuse block and the firewall connector. It is under the masking tape label in the picture. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#117913
01/19/09 06:58 PM
01/19/09 06:58 PM
Posts: 36 Poland
BartekP
Poland
Hi I read this thread carefully as I have lot of question marks in my dash wiring. I'm restoring '70 Challenger SE that I bought in pieces, some of these pieces were from that car, some from other models and the biggest parts of these was missing. I live in Poland and there are just a few Challengers here. Currently I try to put together optional light package. I enclose three photos first(bad picture, separate wire on paper), what is it? lamp has a black cylindrical housing, maybe not from Challenger second (lamp on black floor), is it flood lamp? where it should go? third (switch panel lamp) is it mounted correctly? is it called AC panel lamp? or switch panel lamp? is there any other switch panel lamp? thanks Bartek
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
[Re: BartekP]
#117915
01/19/09 07:04 PM
01/19/09 07:04 PM
Posts: 36 Poland
BartekP
Poland
third picture (how to put more pictures in one post?)
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
[Re: BartekP]
#117916
01/20/09 02:13 AM
01/20/09 02:13 AM
Posts: 500 NoVa
ebodyseast
NoVa
Pic #1 - 95% pos this is NOT for '70 E Body Pic #2 - Lamp and wire for dash switches, installs in dash panel that houses the (3) instrument cluster bulbs Pic #3 - Mounted in correct position.
