Re: Need photo 70 E-Body Backside of Dash Please.
[Re: screamindriver]
#117924
01/21/09 07:51 PM
01/21/09 07:51 PM
Posts: 36 Poland
BartekP
Poland
I have original 70 (I think) key illumination - kind of plastic pipe.
I'll try to connect fuel gauge that way
Yesterday I powered up the wiring, and most of stuff that is already on place work without problems
Wiper motor (3 speed) has some problem, maybe wires in plug are put in wrong order, it stops when I switch them off, it should go back down and stop then. I'm also not sure, shouldn't it have intermittent function? When I turn the switch a bit there is a click and motor starts to operate constantly, next 30deg or more nothing changes, then there is a point where I can feel that switch starts to turn bit harder and motor operates faster and faster to the end of switch movement, is it ok? 3 speed wipers have parking function? there is different motor arm without plastic round insert. ... On wiring diagram I found two blue wires that should go to some A/C delay relay mounted close to blower resistor, but I have no wires like these in my harness, and no relay or a sign of it on heater box, what was it?
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
[Re: BartekP]
#117925
01/22/09 08:02 PM
01/22/09 08:02 PM
Posts: 36 Poland
BartekP
Poland
I have also map light question
map light is powered by pink wire and works with switched ground - yellow wire - but when I connect it to the bullet socket with two yellow wires like diagram says, then map light only works when I open the door - these yellow wires are switched to the ground by door switch, how do You connect it?
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
[Re: BartekP]
#117927
01/25/09 04:31 PM
01/25/09 04:31 PM
Posts: 4,165 Florida
cataclysm80
third (switch panel lamp) is it called AC panel lamp? or switch panel lamp? is there any other switch panel lamp?
I think that's called the heater lamp. It lights up the heater controls (or AC if you have that). If I remember correctly, it came standard on all the E bodies. (probably not on the rare heater delete cars though)
Yes, there are other switch panel lamps.
Tav
[Re: BartekP]
#117928
01/25/09 04:45 PM
01/25/09 04:45 PM
cataclysm80
Pic #2 - Lamp and wire for dash switches, installs in dash panel that houses the (3) instrument cluster bulbs. (EDIT/ADDENDUM 4 BULBS IF YOU HAVE A RALLYE DASH)
Thanks, Now I see rectangular cutout with screw hole on side of light panel
This optional light is usually referred to as "Title Lamp" in factory literature.
That panel has also three big "keyhole" shaped cutouts, what are these for?
The only thing that goes in that panel is the lights. (Note: the 70 challenger panel is slightly different than the one used on all the other E bodies.
any idea where can I find door ajar switches? ones that go on the backside of the door, I have just connectors with inch long plastic pins - kind of part of these switches
That's an extremely hard part to find. Most people are using metal replacements similar to the ones used at the front of the door.
Tav
#117929
01/25/09 04:51 PM
01/25/09 04:51 PM
cataclysm80
Your pic #1 is the AO1 steering column key illumination light after 1970... ..It can't be used with the correct 1970 turn signal/flasher switch....
It also can't be used with the correct 1970 steering column (unless you modify the column).
Tav
[Re: BartekP]
#117930
01/25/09 05:06 PM
01/25/09 05:06 PM
cataclysm80
Hmmm... I don't have an assembled car here to look at right now, but I looked at a map light switch, and mine has a Z shaped grounding strap that grounds the switch housing to the metal dash frame. I'm thinking then that the ground would come through the yellow wire if the door was open, or through the dash frame/switch housing if the switch was ON?
Does it work properly if you ground the switch housing?
Tav
[Re: cataclysm80]
#117931
01/26/09 04:41 PM
01/26/09 04:41 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
HEY GUYS... I GOT IN MY HANDS A NOS 2983696 relay if someone needs. I'm fixing a 70 Charger that I'm not sure if will need or even if this relay is used to 70 B bodies.
[Re: Snoopy]
#117937
02/07/09 04:04 PM
02/07/09 04:04 PM
Posts: 36 Poland
BartekP
Poland
ok, but is it also on and off from one of the pins to the housing?
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
