Converter lug cracked #1178627
02/15/12 12:21 AM
02/15/12 12:21 AM
Bristol, Va
fasteddie Offline OP
Bristol, Va
where it bolts to the flex plate. Cracked at the weld. Is this a common occurrence? It's the first one I've ever heard of.
Re: Converter lug cracked [Re: fasteddie] #1178628
02/15/12 05:55 AM
02/15/12 05:55 AM
Not common, What brand and what size converter?
Re: Converter lug cracked [Re: fasteddie] #1178629
02/15/12 11:44 PM
02/15/12 11:44 PM
Bristol, Va
Bristol, Va
It's a 10 inch from PTC. It is not my intent to slam PTC at all. It has hundreds of runs on it and a few nitrous runs. It has been a good converter. The car has been deadly consistant and has helped me be in the money at quite a few races. Had a leak I thought was a front seal but my trans guy didn't think it was the seal and asked to see the converter. Sure enough, cracked weld. He also said it was a ford converter adapted to a mopar. I thought that was kinda odd.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Converter lug cracked [Re: fasteddie] #1178630
02/15/12 11:56 PM
02/15/12 11:56 PM
in the old days the Falcon 10 inch converter was the one most shops adapted to drag race applications with a 10 inch converter, Ford Cortina nine inch and Opel 8 inch where used also for drag racing A friend of mine went through the cracking lugs on his older 8 inch race converter, had it repaired twice after breaking it pretty severaly the first time and then reinjuring it the second time He ended up buying a new 9.5 inch after the second time, racing parts wear out
Re: Converter lug cracked [Re: Cab_Burge] #1178631
02/16/12 03:43 PM
02/16/12 03:43 PM
Bristol, Va
Bristol, Va
I'm with ya Cab. I have pretty much worn this one out. I told my trans guy to repair and rebuild it and I would put it on the shelf as a back up. This also gives me a chance to run the new J.W. converter and do a comparison.
Re: Converter lug cracked [Re: fasteddie] #1178632
02/17/12 12:02 AM
02/17/12 12:02 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
I had one crack,we took all the big bad welds out with a grinder and welded them all the way around with tig, not just on two sides.~~ bent
Section 8 Racing We are nuts about racing.
Re: Converter lug cracked [Re: bentwheel43] #1178633
02/17/12 06:44 AM
02/17/12 06:44 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
I had my 10 year old lupo convert
or crack at the lugs too.
