max wedge port size #1178618
02/14/12 11:29 PM
02/14/12 11:29 PM
S.E. WI
allmopar Offline OP
allmopar  Offline OP
S.E. WI
I am trying to find out the approximate dimmensions (height &width) of the max wedge ports on indy heads. Gasket dimensions are fine.
Re: max wedge port size [Re: allmopar] #1178619
02/15/12 01:03 PM
02/15/12 01:03 PM
NC
440Jim Offline
440Jim  Offline
NC
BB Mopar Intake gasket dimensions
1.40 x 2.72 (Mr Gasket #302)
1.34 x 2.63 (Indy 440-G1-221)
1.47 x 2.70 (Indy 440-G1-222 for 572-13 heads)
1.38 x 2.63 (Superperformance gaskets)
Re: max wedge port size [Re: 440Jim] #1178620
02/15/12 02:22 PM
02/15/12 02:22 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
If you'd like actual dimensions I can measure my heads when I get home.
Re: max wedge port size [Re: 440Jim] #1178621
02/15/12 04:49 PM
02/15/12 04:49 PM
tboomer Offline
tboomer  Offline
Them there are some big ports!! Can't wait to get mine back!!
Re: max wedge port size [Re: Max Wedge Savoy] #1178622
02/15/12 06:57 PM
02/15/12 06:57 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Yes, please.
Dennis
Re: max wedge port size [Re: cudaboy] #1178623
02/15/12 07:16 PM
02/15/12 07:16 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Mr Gasket #302 gasket for max wedge heads has a opening of 2.72 h x 1.40 wide. Or call Indy to see if this is correct. Hope this helps.
