PVC location question #1178241
02/14/12 01:36 PM
02/14/12 01:36 PM
Finally a HUSKER again
Moparnut426 Offline OP
This may seem like a dumb question for some of you guys, but on a 69 sixpack intake, where does the pvc valve hook up to? and on whick side is the pvc valve cover go on?
Im thinking its the back of the intake, and the vc goes on the drivers side, but I can not confirm that.
Kasey
Re: PVC location question [Re: Moparnut426] #1178242
02/14/12 01:44 PM
02/14/12 01:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
PVC is located in the plumbing aisle...
PCV plugs into the passenger side of the center carb...
Re: PVC location question [Re: 1_WILD_RT] #1178243
02/14/12 02:03 PM
02/14/12 02:03 PM
MA
stumble bee Offline
stumble bee  Offline
MA
'69 valve covers,the oil fill goes on the drivers side front segment
and the PCV valve goes on the pass side rear segment
Re: PVC location question [Re: Moparnut426] #1178244
02/14/12 02:19 PM
02/14/12 02:19 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Kasey, I hope it is okay to ask this in your thread. How important is it to have a PCV valve in addition to the crank case breather that is plumbed to the air cleaner? Can the PCV be eliminated on an older street driven car?
BigBlock 74 Swinger
Re: PVC location question [Re: bb74swngr] #1178245
02/14/12 02:41 PM
02/14/12 02:41 PM
MA
stumble bee Offline
stumble bee  Offline
MA
I think you should run a PCV valve, too much crank case pressure can cause gasket oil leaks everywhere, also you could have better ring seal with positive crankcase ventilation
Re: PVC location question [Re: 1_WILD_RT] #1178246
02/14/12 03:11 PM
02/14/12 03:11 PM
LOL,,, Sorry for the bad case of dyslexia. And spelling....
And thanks, I know there is a plug on the back of the intake, and it looks like its for a vacum tree. Also this is a 70 set up on a 69 engine, and well its going in a 88 rancharger. But I want it to look correct, and function properly.
Thanks again guys.
KAsey
Re: PVC location question [Re: stumble bee] #1178247
02/14/12 03:12 PM
02/14/12 03:12 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Thank you Shawn. I was really hoping for a different answer, but I am sure you're right...darn it:) Thank you.
BigBlock 74 Swinger
