drop spindles #1177877
02/13/12 06:54 PM
02/13/12 06:54 PM
NC
P
phil4161972 Offline OP
P
NC
I did a google post and saw these http://www.helixsuspension.com/catalog/S...-Bracket-(Pair)
any body ever used these or heard of them?
Re: drop spindles [Re: phil4161972] #1177878
02/13/12 08:12 PM
02/13/12 08:12 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Never heard of them - They don't mention how much of a drop they give you - everyone seems to be using the fatman spindles or the magnumforce ones...
Re: drop spindles [Re: dangina] #1177879
02/13/12 08:20 PM
02/13/12 08:20 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If you have to use their brackets that sucks for brake upgrades.
Mopar to the bone!!!
Re: drop spindles [Re: 72Swinger] #1177880
02/13/12 09:48 PM
02/13/12 09:48 PM
IN
ahy Offline
ahy  Offline
IN
OE or OE replacement spindles are drop forged... very strong and tough.
I understand the dropped spindles are one form or another of casting... some better than others but none as tough as forged steel. MA ran an article on the different types last year.
With big T bars and maybe a little trimming of the bump stops you can drop the OE suspension a fair amount with the adjusters... a much better solution I believe.
Re: drop spindles [Re: phil4161972] #1177881
02/13/12 11:25 PM
02/13/12 11:25 PM
AndyF Offline
AndyF  Offline
The picture doesn't show a dropped spindle. My guess is that is just the standard aftermarket knuckle that has been on the market for a while. The description may not be accurate.
Re: drop spindles [Re: phil4161972] #1177882
02/17/12 09:21 AM
02/17/12 09:21 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Would some one please explain to me using data and experience why dropped spindles are are needed?
A car can be only so low before contact with objects...
Re: drop spindles [Re: ThermoQuad] #1177883
02/17/12 03:20 PM
02/17/12 03:20 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Drop spindles can give you an opportunity to utilize more shock travel while you keep the same Center of Gravity location. Other then that, to me, there is not much benefit unless you know exactly what you are trying to accomplish.
If you think that throwing drop spindles on will help the car handle better, this is not correct. The most important factor in all this is your Roll Center. Using drop spindles is effectively raising your roll center, which is not ideal for racing situations.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: drop spindles [Re: Viol8r] #1177884
02/19/12 12:21 PM
02/19/12 12:21 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I'm curious too...I have the front of my 68 charger lowered a little but what have I actually done by backing off the adjusters on the Tbars? I always thought drop spindles were just a better way to lower a car because you can get lower ride height with the same suspension adjustments. does backing of the adjusters do anything to the spring rate of the bar? or does it change any of the other alignment specs? I had it aligned at it's current "lower" height...so with all things being equal are drop spindles enough of a better way to lower a car to justify the cost?
oh... and I looked at the spindles in the OP's link. I don't think they are drop spindles at all, just drop forged like your old craftsman wrenches lol.
Re: drop spindles [Re: Pool Fixer] #1177885
02/19/12 02:10 PM
02/19/12 02:10 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You are correct. The spindle pictured is not a drop spindle. If they are selling what is in the picture they that listing is totally false and misleading.
BTW the picture of the spindle is upside down. Most everyone displays a part for sale in roughly the installed position. IMHO, further showing the seller has no clue what he is selling.
The spindled pictured are just the same spindle everyone is selling for disk brake conversions; Right Stuff, PST, Just Suspension, etc, etc...
Re: drop spindles [Re: autoxcuda] #1177886
02/19/12 02:12 PM
02/19/12 02:12 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This is what a Mopar dropped spindle looks like:
Re: drop spindles [Re: phil4161972] #1177887
02/21/12 07:13 PM
02/21/12 07:13 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Stock spindles can bent almost 90° w/o breaking (drop forged). All the aftermarket ones are some premium cast "Austermpered"). Judge for yourself:
Drop Spindle Test Video
Rick
Re: drop spindles [Re: Rick_Ehrenberg] #1177888
02/21/12 07:18 PM
02/21/12 07:18 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Rick
The helix spindles are drop forged according to their ad.
Re: drop spindles [Re: moparpollack] #1177889
02/21/12 08:05 PM
02/21/12 08:05 PM
Marlboro, NY, USA
Marlboro, NY, USA
I sincerely hope so! But the title of the post was "drop spindles", so that's where I went.
Do we know if the Helix knuckles are large bearing? Tall (73-up)? Caliper adapters they show: 10.87 or 11.75"?
Rick
Re: drop spindles [Re: Rick_Ehrenberg] #1177890
02/21/12 09:47 PM
02/21/12 09:47 PM
85086
Lil Herman
Lil Herman
85086
Rick
I never knew Lemmy was a mopar fan.
Re: drop spindles [Re: phil4161972] #1177891
02/22/12 09:47 AM
02/22/12 09:47 AM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: drop spindles [Re: cogen80] #1177892
02/22/12 11:52 AM
02/22/12 11:52 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I'd say this is all similar to opinions engine builders have about forged cranks vs the newer cast steel units and wheel manufactuers have been spouting about forged vs cast wheels for decades. A lot of progress has been made in the casting process and materials that they use are not as brittle as they were in decades past, but a casting will still fail before a forging.
However, using a sledge to hammer on a spindle that is retained at the very tip of the threads isn't really representative of the way loads are carried by and transfered through the part. The tip of the spindle does not carry the entire force of the load put in to the component, so the fact that it broke doesn't suprise me. Clamp the spindle at the lower ball joint surface and then hammer at it and see what happens then.
From what I've seen on the market, there are only two drop spindles out there for mopar applications. There are the Fatman units that are basically a plate with a pressed in stub shaft and welded upper ball joint tab (and they weigh a lot!) and these cast steel units that I "think" originated at Magnumforce, but are resold through several different vendors such as PST, Just Suspension, and maybe even Helix. IMO, Helix needs to update their website to more properly represent what they are selling as their description doesn't match their picture.
There are some practical uses for drop spindles in competition applications where the range of adjustment is great enough to correct the geometry issues that results from their use. Drop spindles do create additional bump steer problems because of the change of position of the inner tie rod pivot points that results from the overall change of chassis position.
For the average cruiser crowd who wants a lower look with soft wheel rates that need the extra travel to avoid bottoming out, they are perfect. For a performance enthusiast with a basically stock layout and higher wheel rates on a relatively smooth surface, like a track, there isn't a lot of benefit compared to the tried and true turn down the t-bars approach.
Re: drop spindles [Re: TC@HP2] #1177893
02/22/12 12:54 PM
02/22/12 12:54 PM
NC
P
P
NC
While the testing method may be questionable its no doubt that the cast spindles are weaker than factory. So, for a street car where a lowered stance is desired are you better off going to the drop spindle or getting adjustable UCA to gain the caster and camber adjustment needed for the correct alignment?
Re: drop spindles [Re: TC@HP2] #1177894
02/22/12 01:33 PM
02/22/12 01:33 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
How does the inner tie rod pivot position change with drop knuckles?
As far as I know, the location of the upper and lower ball joints as well as the tie rod stay in the same place. The only thing moved upward is the spindle and caliper mounts.
I can see how lowering a vehicle by relaxing the torsion bars would cause that problem, however.
Re: drop spindles [Re: DoctorDiff] #1177895
02/22/12 02:48 PM
02/22/12 02:48 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Legit question. All things being equal drop spindles would raise the inner mounting point of the tie-rods vs. lowering stock suspenion. Whether that is a noticable effect of bump, not sure. I would think if you are real serious about all this, these things will need to be checked before you hit the track.
I attached a few different scenarios of the effect that drop spindles can have on roll center. Bottom line is if you just bolt on drop spindles you effectively raise your roll center, unless mods are made. Your car will appear lower but the performance could be compromised. These are hypothetical drawings, just for reference.
7084914-RC.pdf (277 downloads)
Re: drop spindles [Re: DoctorDiff] #1177896
02/22/12 02:56 PM
02/22/12 02:56 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yup...
and I do agree, pounding on the tip of the spindle with a sledge is not scientific, repeatable, or any way representative of the way the part is loaded. With no strain gages measuring strain and a controlled and measured application of force, you have no way of saying which are "stronger". Personally, as an engineer, I'd be embarrassed to have my name associated with this "test", but that's just me. yeah, a low carbon factory forging might bend over before it breaks, but how much force caused it to bend?
Magnumforce claims their parts are 130ksi ultimate tensile strength austempered ductile iron...a typical 1018 forging has a UTS of about 64ksi with a yield of about 54ksi. 1010 forgings are about 44ksi yield, 53ksi UTS. in the ferrous world, UTS and yield are related to the hardness of the material-- the harder the material, the more stress before yield. Again in the ferrous world, the harder the steel, the less % elongation before failure (the part snaps instead of folding over).
Austempering is a special heat treat process used mainly with ductile iron that allows the continuous steel phase to remain in it's austinetic crystal structure at room temperature instead of forming martensite in a traditional Q&T process. you end up with a more homogeneous grain structure, and a stronger, less brittle part..you typically see higher yeild and UTS levels with higher % elongation than you see in typical Q&T steel. austempered ductile iron can give an ultimate tensile strength as high as some of the strongest quench and tempered alloy steels....played a bit with it in my days at college.
granted, I can't say if the cast spindles are truly austempered, but in theory, a cast part, if properly processed, can be as strong as a forged part. the forging process works by refining the grain structure of the material. if you do heat treating to it, you eliminate any advantage of the forging process over casting, because part of the heat treating process is heating it into it's austinetic phase to basically "re-do" it's grain structure.
and to the other poster, spring rates are dependent on geometry of the spring and elastic modulus of the material. in a torsion bar, spring rate is determined by the elastic modulus of steel, the diameter, and the free length. cranking down the t-bars to lower, you're just reducing preload, but not altering spring rate.
2017 Grand Cherokee Overland
