K-motion valve springs #1177592
02/13/12 09:00 AM
02/13/12 09:00 AM
Mi USA
Dyno Donnie Offline OP
Mi USA
Anybody using K-950 springs. Have not always heard positive
feed-back on K-Motion's. Im new to moparts Hello Hello
Re: K-motion valve springs [Re: Dyno Donnie] #1177593
02/13/12 09:38 AM
02/13/12 09:38 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
Yup, I used them. Couldn't get more then a year out of them before I started to float valves... and that was using a mild roller cam (well within their specs). After 2 sets (kinda hard headed) I made the switch to PAC and never looked back. They cost more, but they last a whole lot longer. No more floating valves, broken rocker arms and bend valves. Guess the PAC springs aren't that expensive after all. In short... keep looking. Good Luck
Re: K-motion valve springs [Re: Dyno Donnie] #1177594
02/13/12 12:55 PM
02/13/12 12:55 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I'm still using Kmotion K950. They've worked ok for me. I check the seat pressure on a regular basis and I shim them as needed.If I were buying new springs I sure might look for another brand though. If using them be sure to use hardened shims under them as the dampers will saw through soft shims or aluminium heads. welcome to moparts
Re: K-motion valve springs [Re: Dyno Donnie] #1177595
02/13/12 01:21 PM
02/13/12 01:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to run K-motion springs... they do tend to
break... I changed over to PAC springs and have been
very happy... with much more life out of them
Re: K-motion valve springs [Re: Dyno Donnie] #1177596
02/13/12 02:33 PM
02/13/12 02:33 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I've been running the K975-H springs and they seem to do well for me, I have ran them for 3 years now but I have a small cam.
Re: K-motion valve springs [Re: SB412DUSTER] #1177597
02/13/12 02:42 PM
02/13/12 02:42 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
anyone got a link for PAC springs?
Re: K-motion valve springs [Re: dartman366] #1177598
02/13/12 03:52 PM
02/13/12 03:52 PM
NC
440Jim Offline
440Jim  Offline
NC
I typed "PAC valve springs" into the Bing search engine and found:
http://www.racingsprings.com/
Re: K-motion valve springs [Re: 440Jim] #1177599
02/13/12 03:56 PM
02/13/12 03:56 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
is there a cross reference from k1000h's to a pac number so I can keep my retainers...
Mopar Performance
Re: K-motion valve springs [Re: Dyno Donnie] #1177600
02/13/12 07:18 PM
02/13/12 07:18 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'm runnin isky toolroom steel. came with dyno sheet. still perfect, 2 yrs old. great spring. seeya.
Re: K-motion valve springs [Re: rickraw] #1177601
02/13/12 08:54 PM
02/13/12 08:54 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
K 950's I get 600 runs and I change me cause they are gonna break after that. I know from experience. Typically happens in cold weather after 600 passes. Cant argue with that kind of life though. .704 lift with a 1.6 rocker and 280 @.050
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: K-motion valve springs [Re: 440Jim] #1177602
02/14/12 05:05 AM
02/14/12 05:05 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thanks Jim.
Re: K-motion valve springs [Re: Dyno Donnie] #1177603
02/14/12 12:04 PM
02/14/12 12:04 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I would suggest PAC, PSI,NexTek and Isky in that order.
RIP Monte Smith
Re: K-motion valve springs [Re: CompWedgeEngines] #1177604
02/14/12 05:18 PM
02/14/12 05:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've had good luck with K1100 springs but with
smaller cams, .600 to .650 gross lift
Rich H.
Esse Quam Videri
