Looking for a 1/2" crank pulley spacer #1177378
02/12/12 08:19 PM
02/12/12 08:19 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Does anybody out there make one? I changed balancers and need to adjust the crank pulley now.
DMI makes a nice one but it is 5/8" thick and I would rather not have to move the rest of my stuff out if I don't have to. Thanks for any help.
68 Barracuda Formula S 340
Re: Looking for a 1/2" crank pulley spacer [Re: Bad340fish] #1177379
02/12/12 08:33 PM
02/12/12 08:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think the Mancini one from AR Engineering is 3/8"thick to match the motor plate
Gus
64 Plymouth Savoy
Dana 60
Re: Looking for a 1/2" crank pulley spacer [Re: fourgearsavoy] #1177380
02/12/12 11:41 PM
02/12/12 11:41 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
If you can't find one it's fairly easy to
make , most machine shops could make one for you
Re: Looking for a 1/2" crank pulley spacer [Re: DavidDean] #1177381
02/13/12 12:19 AM
02/13/12 12:19 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
deleted
Re: Looking for a 1/2" crank pulley spacer [Re: Bad340fish] #1177382
02/13/12 11:46 AM
02/13/12 11:46 AM
NC
440Jim Offline
440Jim  Offline
NC
I thought DMI sold a bunch of different thicknesses. Give them a phone call and check.
If you have a machine shop make one, be sure and tell them you need the centering ring on both sides (centered on balancer, centered on pulley). Not just a big clearance hole letting the pulley be centered by the bolt pattern.
Re: Looking for a 1/2" crank pulley spacer [Re: Bad340fish] #1177383
02/13/12 12:41 PM
02/13/12 12:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A piece of 1/2" alum round stock and a few holes and
your done.... trace the holes off your pulley
Re: Looking for a 1/2" crank pulley spacer [Re: Bad340fish] #1177384
02/13/12 12:56 PM
02/13/12 12:56 PM
AndyF Offline
AndyF  Offline
Just have DMI build you a pulley to the correct length. He builds pulleys with an extra thick base which allows you to easily adjust the height.
