Date code on electrical motor? #1177231
02/12/12 03:50 PM
02/12/12 03:50 PM
SE PA.
Q
QuickBpBp Offline OP
Q
SE PA.
Learning how to read some codes on different stuff and I got an electrical motor with some Charger parts. I want to know what it all means and what I think it means???
It reads on the barrel.
3431437
7369
2146
I am thinking March 7th 1969 by the center #'s.
Is that correct?
What do the bottom #'s represent.
Thanks in advance...
Re: Date code on electrical motor? [Re: QuickBpBp] #1177232
02/12/12 04:15 PM
02/12/12 04:15 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
It's a headlight door motor for a '70 Charger. Built on the 73rd day of '69.
Re: Date code on electrical motor? [Re: John_Kunkel] #1177233
02/12/12 04:33 PM
02/12/12 04:33 PM
SE PA.
Q
Q
SE PA.
So this 4 digit code is not day month year...
I knew it was a headlamp door motor just didn't know if it was the "correct" dated one...
Thanks..
Are the numbers underneath are dealer vendor #'s?
Re: Date code on electrical motor? [Re: QuickBpBp] #1177234
02/13/12 08:49 AM
02/13/12 08:49 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Sorry John. That is incorrect.
The date code are the bottom numbers.
7369 is the vendor code.
2146 is the date code. It is the 214th day of 1966 or Aug the 2 nd of 66.
Jules
Re: Date code on electrical motor? [Re: JulesdaWiperman] #1177235
02/13/12 09:21 AM
02/13/12 09:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
..... since this headlight motor didn't exist in '66 & was used thru the '70s on other hidden headlight Dodges (other Mopars?).
2146 = Sunday, August 1, 1976
Re: Date code on electrical motor? [Re: 6bblgt] #1177236
02/13/12 09:30 AM
02/13/12 09:30 AM
super gas
super gas
The part number would be too early for a 77 I think.
Maybe it is a mis stamp date code.
The 437 part number was usually found on 71/72 Chargers.
Or it may have been carried forward to 77.
The info on this seems to be conflicting.
Weren't there 67 C bodies with headlight motors?
Jules
Re: Date code on electrical motor? [Re: JulesdaWiperman] #1177237
02/13/12 10:01 AM
02/13/12 10:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
from Chrysler "parts catalogs":
8-34-280 - MOTOR, Headlamp Rotating
'66 catalog -
Charger (2) = #2631 334
'67 catalog -
'68 catalog -
300 = #2889 247
'69 catalog -
300 / Imperial = #3431 026
'70-'71 catalog -
Charger / 300 / Imperial ('70) = #3431 438
Sport Fury / Gran Coupe ('70) = #3431 437
Charger / Sport Fury / GT ('71) = #3431 437
300 / Imperial ('71) = #3431 438
'74 catalog -
Imperial = #3431 438
'75 catalog -
Dodge c-body / Imperial = #3431 437
'76 catalog -
Dodge c-body / Chrysler = #3431 437
'77 catalog -
'78 catalog -
XS / CS = #3431 437
Re: Date code on electrical motor? [Re: 6bblgt] #1177238
02/13/12 10:39 AM
02/13/12 10:39 AM
super gas
super gas
This part number doesn't seem to show up on the list.
Should also be 70 Charger.
Thanks for the list Dan.
Jules
Re: Date code on electrical motor? [Re: 6bblgt] #1177239
02/13/12 04:41 PM
02/13/12 04:41 PM
SE PA.
Q
Q
SE PA.
So it probably was a replacement one???? Are all the date codes on the bottom then when they are "written" like this?
So it's...
Part #
Dealer vendor #
Date code
Thanks again for any info just trying to learn how to read some of these...
Re: Date code on electrical motor? [Re: QuickBpBp] #1177240
02/13/12 05:11 PM
02/13/12 05:11 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Unless it's near NOS. It was probably originally installed on a '77 Dodge c-body or Chrysler & later removed from said car in a junkyard and may or may not have ever been installed on a Charger. Parts/numbers/dates/location/format varied regularly.
Part #3431437
vendor #73691 (this is a number CHRYSLER CORP. assigned to the motor's manufacturer) Jules - Do you know who it was?
Date code 2146 (214th day of 1976 - Sunday 8/1/76)
73691
2939 (393rd day of 1969 - Monday 10/20/69)
I couldn't find any reference to this part number. The '70-'71 Catalog I have is the Jan.'72 "final version" - I'd guess it was an early version and replaced during 1970 for either the 3431437 or 3431438 (what's the difference between the two 437/438 ?). I've had a number of the '70 Fury type, including a couple with a rubber "boot" over the working end of the motor, did they all have the "boot" 211/437/438 or is that one of the differences between Charger & Fury?
Are there 1969 dates for 3431437 & 3431438?
Re: Date code on electrical motor? [Re: 6bblgt] #1177241
02/13/12 07:15 PM
02/13/12 07:15 PM
super gas
super gas
Dan,
I wish I could be more of a help but headlightmotors are not my strong point.
The only differences I have noticed is that some motors have rectangular holes in the gears and some have square holes.
I know that 70 Chargers use the square holes. 211 motors seem to have the large wheel at the bottom. All others have the small wheel.
I have yet to recieve a motor for rebuild with a rubber boot on it.
I do not know who the vendor code is.
Jules
