Ignition light 1968 GTX #1177032
02/12/12 01:01 PM
02/12/12 01:01 PM
btomasko Offline OP
btomasko  Offline OP
Does this have one of those time delay lights? I dont think mine does,where would you connect the light wire from the ignition switch to? thanks and how would you change out the bulb?
Re: Ignition light 1968 GTX [Re: btomasko] #1177033
02/12/12 01:10 PM
02/12/12 01:10 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
you mean like in the dash?, i dont think they have one.
Re: Ignition light 1968 GTX [Re: btomasko] #1177034
02/12/12 01:34 PM
02/12/12 01:34 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I think they only came on the cars that had the light package ordered. It is a seperate deal from the ignition system. There is a flat metal bracket that has a small bulb socket on top that sticks out over the key. There should be a small hole directly above the key in the soft pad. The wire runs over to the fuse box and is powered by the dome light circuit. There is a small capacitor that keeps a charge for 5-10 seconds that keeps the light lit after the doors are shut.
Re: Ignition light 1968 GTX [Re: btomasko] #1177035
02/12/12 01:37 PM
02/12/12 01:37 PM
cbusters Offline
cbusters  Offline
69 has that. It is an option that includes the Map Light and a delay that works for the dome light also. The ignition light is in a bracket that fits between the ignition switch and the dash. Easy to identify the wiring package, it has a lot of pink wires.
Re: Ignition light 1968 GTX [Re: cbusters] #1177036
02/12/12 02:48 PM
02/12/12 02:48 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
68's have it too.My folks had a 68 GTX and it had the ignition light.
Nautilus Racing-
Re: Ignition light 1968 GTX [Re: btomasko] #1177037
02/12/12 03:28 PM
02/12/12 03:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My 68 GTX has it and the map light no longer works and car slowly morphed into drag only!
Re: Ignition light 1968 GTX [Re: btomasko] #1177038
02/12/12 05:49 PM
02/12/12 05:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
it has to be removed to change the bulb. (ignition switch removal).
