Other cheap mods for a street car?
#1176834
02/12/12 03:06 AM
02/12/12 03:06 AM
Posts: 819 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I just fired my new cam this afternoon (thanks to everyone who helped, this forum is seriously the best) and I'll be putting my Carter AVS on in another weekend or two. I already have an MSD-6AL and whatever vacuum advance distributor usually came with the Mopar orange box kits. Is there anything else relatively cheap I can do to the car to pick up some power? I only have 2.93 gears in the rear (742) but differential work seems to get expensive really quick. I don't know how cheaply complete 3.23 or 3.55 third members can be found for but nobody's selling them around here. Distributor recurve maybe?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Other cheap mods for a street car?
[Re: Secret Chimp]
#1176835
02/12/12 03:08 AM
02/12/12 03:08 AM
Posts: 489 NE
bigtail
NE
I'mm not a big fan of it, but NOS? seems to give bang for the buck.
This page is made up completely of recycled electrons.
[Re: DaytonaTurbo]
#1176837
02/12/12 03:37 AM
02/12/12 03:37 AM
Secret Chimp
Eugene, Oregon
Distributor recurve is always a good idea, and I would do it either way. But it's still going to suck with those 2.93 gears. Great for highway cruising, sucky for punch around town.
Yeah really. Especially considering people still reporting 20+ mpg when using those ratios. I like the new power from this cam but I'm breaking the law by the time I'm out of 1st half the time! I'd drop $230 on a new set of gears if I could set them up myself, but I don't have any of the tools to do it right.
Do you know what the go-to kit is for Mopar dists on street cars? I've heard people talking about certain Mr. Gasket kits intended for Chevies, but I don't want to go chopping up the bits in my distributor to make them work right.
[Re: gch]
#1176839
02/12/12 05:00 PM
02/12/12 05:00 PM
RapidRobert
HP ex manifolds/mandrel bent exhaust/dynomax muffs/X pipe/resonators for noise reduction & dial in the dist subsystems one at a time IN ORDER. As said the gears are gonna hurt you bad. good cam choice I'm assuming. EDIT correct converter choice also
[Re: forphorty]
#1176841
02/12/12 06:29 PM
02/12/12 06:29 PM
Posts: 5,169 CT
GTX MATT
CT
IDK I had a Mopar Performance Dizzy that came with one light spring and one governor spring, just like the factory ones. I did get it cheap second hand though, so it could have been fooled with and IDK when it was made.
For what its worth put a timing light on your car and see where the timing is all in at. If its much above 2000 rpm go on summit racing look for re-curve kits for a Chrysler 440. Buy the Mr Gasket one for 5 dollars or whatever it is. Disassemble your dizzy and take out the heavier of the two springs that may be in there, if they are the same then it obviously doesn't matter. Replace it with the Mr. Gasket spring and you should have full advance ~2000 rpm, depending on the weights you have.
And 2.93s are incredible galaxies away from 3.55s.
