Re: 1970 B-Body Reverse light
[Re: WH23H6]
#1176726
02/12/12 12:30 AM
02/12/12 12:30 AM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
Here is a photo of the 70 reverse light location! It is the hole to the right of the air grabber switch.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#1176727
02/12/12 12:31 AM
02/12/12 12:31 AM
70gtx440dana
Lansing, MI
The hole lines up with the oval shown in the frame.
[Re: 70gtx440dana]
#1176728
02/12/12 12:33 AM
02/12/12 12:33 AM
70gtx440dana
Lansing, MI
If I remember correctly....One wire goes directly from the ligth to the bulkhead connector.
[Re: 70gtx440dana]
#1176730
02/12/12 11:08 AM
02/12/12 11:08 AM
Posts: 134 Closest Race Track
WH23H6
Closest Race Track
Another photo....
Thats perfect thanks for the help....
One last question....how does that light ground...? being installed in plastic..the light and housing that I have only has one wire coming from it....
[Re: WH23H6]
#1176732
02/12/12 01:36 PM
02/12/12 01:36 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Another photo....
The light housing is grounded to the dash frame.
[Re: 62maxwgn]
#1176733
02/13/12 06:56 PM
02/13/12 06:56 PM
WH23H6
Closest Race Track
Another photo....
How does it do that when its mounted in plastic? The oval hole in the frame is quite big...the light housing never touches metal...in a 68 - 69 car its in the metal frame but in 1970??
[Re: WH23H6]
#1176736
02/13/12 11:48 PM
02/13/12 11:48 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
You should be able to make the light work very easily. On the metal socket that pushes into the light housing just solder a piece of wire to the housing that is long enough to reach the metal dash frame and solder a ring end on it and you should be good to go.
68 Charger R/T 440 auto
