Rebuilding a 70 E Body Steering Column Questions #1176640
02/11/12 08:10 PM
02/11/12 08:10 PM
moparmedic Offline OP
I want to rebuild my steering column for my 70 Challenger. It is a floor shift column. I have been on line looking for parts. Year one carries some stuff but but I can't figure out which bushings and bearings to get. Part numbers would be helpful. Any other vendors out there for parts? Any tips for doing a rebuild? I have a shop manual as a guide.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: Rebuilding a 70 E Body Steering Column Questions [Re: moparmedic] #1176641
02/11/12 09:10 PM
02/11/12 09:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Rebuilding a 70 E Body Steering Column Questions [Re: moparmedic] #1176642
02/11/12 09:18 PM
02/11/12 09:18 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You need a parts book bad too. Look around on here i found a free download. There are a lot of bearnings ect on ebay but they usualy cost more than a parts outlet.Also if it's on ebay then someone else has it too.
Re: Rebuilding a 70 E Body Steering Column Questions [Re: 71birdJ68] #1176643
02/11/12 10:22 PM
02/11/12 10:22 PM
BDW Online content
BDW  Online Content
Is your email corrrect? I'll send you a great How-To I saved
Re: Rebuilding a 70 E Body Steering Column Questions [Re: moparmedic] #1176644
02/12/12 12:32 PM
02/12/12 12:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Lower bushing looks like this
upper bearing if needed is still avail thru Mopar
Turn signal switch is still avail thru Mopar BUT it is a superseded swtich and is slightly different from original ( hazard switch knob is different)
Ignition switch went NS1 last year but it's avail thru the aftermkt
Re: Rebuilding a 70 E Body Steering Column Questions [Re: gtx6970] #1176645
02/12/12 01:20 PM
02/12/12 01:20 PM
Thanks for the info and thanks CNXT and Alaskan TA for the guides.
Anyone have the part numbers? Is the lower bushing available from mopar too?
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
