Re: Addco front bar kit, anyone use their brackets?
[Re: mkvien]
#1176556
02/11/12 04:56 PM
02/11/12 04:56 PM
Posts: 27,470 So Cal
autoxcuda
So Cal
Got a good deal on front and rear sway bar kit for my 68 Coronet that didn't come factory with either. Figured it would be better than nothing, and I am not a racer. Anyway, their 154 front kit comes with brackets to mount the ends on the lower shock bolt, think I have that figured out. The K-member brackets look like they will put the bar brackets right into my lower radiator hose if I use them, unless I am installing them wrong. I am about ready to figure out my own brackets unless someone can maybe help me out? The also look like they sill try to put a rearward pressure on the bar if I put them on and tighten the bolts. Anyone have experience? Haven't even looked that the rear yet.
Thanks.
Use this kit from Energy to mount the sway bar to the holes that are allready in your K-member for the factory sway bar. Sometimes K-members are missing the/some holes. You can just drill them.
Bolts to these two holes:
[Re: plazomat]
#1176559
01/17/13 12:28 AM
01/17/13 12:28 AM
autoxcuda
So Cal
Hey gents anyone have a part number and cost for those energy mounts shown?
Plaz
Search sway bar mount at www.summitracing.com
