Need a master cylinder gasket quick? #1176394
02/11/12 11:23 AM
02/11/12 11:23 AM
illinois
bigblk66_coronet Offline OP
illinois
Im getting ready to put my master cylinder on and i need a gasket quick. Other than odereing a whole kit is there any quick fix?........thanks joe
Re: Need a master cylinder gasket quick? [Re: bigblk66_coronet] #1176395
02/11/12 11:54 AM
02/11/12 11:54 AM
get a sheet of thin gasket material at your parts house & use the M/C flange as a template & cut out a piece EDIT Quicker yet if you have a red green or yellow manila folder around the house cut a piece & spray it on both sides w Permatex "high tack" the red stuff in a spray can. A light even coat. I'm serious. I used it for a BB oil pump to block face gasket & no leak
Re: Need a master cylinder gasket quick? [Re: RapidRobert] #1176396
02/12/12 01:46 PM
02/12/12 01:46 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
It would help if we knew what MC you need it for. I have a new Bendix 2225441, brand new $10 shipped to you tomorrow. pauls340 at comcast dot net
Still looking for LM29H1B415501, '71 Demon 340
Re: Need a master cylinder gasket quick? [Re: PAULS_340] #1176397
02/12/12 04:43 PM
02/12/12 04:43 PM
Oh that gasket
