E-body remote mirror question
#1176159
02/10/12 07:07 PM
02/10/12 07:07 PM
Posts: 4,325 St. Louis, Mo
318 Stroker
St. Louis, Mo
I have the driver side remote mirror from my 73 Challenger off of the car right now. Surrounding the 3-cables bundle are a couple of "clips" or retainers. One is plastic, and has a couple of tabs or ears, which I believe pop into a hole in the inner door structure, on the forward end of the door. There is also a metal "clip", between the mirror base and the plastic retainer. It appears to help hold, or retain the routing of the cables. This metal clip also has one end bent over, and it appears that this bent-over area would swedge over a thin piece of sheetmetal somewhere in the door. Where does this metal clip mount?
Re: E-body remote mirror question
[Re: 05dakota]
#1176162
02/11/12 10:51 AM
02/11/12 10:51 AM
Posts: 4,924 new berlin wisconsin
Mr T2U
the thin piece of metal is to hold the adjuster on the door panel. it slides on the top of the adjuster to keep it from pulling thru the door panel when you but the bezel on the front of the panel. there should be 2 or 3, been over 10 years since i worked on one so i don't remember exactly, plastic clips on the cable. they hold the cable to the front of the door structure. this is so the cable doesn't get tangled up with the door glass when rolling it up and down.
perception is 90% of reality
