Re: Fair price to paint a 'Cuda hood?
[Re: GoodysGotaCuda]
#1175273
02/09/12 10:17 AM
02/09/12 10:17 AM
Posts: 4,244 West Virginia
NewbombTurkk
West Virginia
Borrow a gun/water trap and do it yourself.........very easy to do.....if you mess up...sand and redo......very easy....
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
[Re: elitecustombody]
#1175277
02/09/12 10:32 AM
02/09/12 10:32 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
yup, it's all time and materials, and materials ain't cheap!
so buy good materials, and do the time yourself.
I dabbled into some paint and body on my Dakota, spent $250 in materials (the intense blue paint was $130 a quart alone, plus primers, little bondo, clear coat, thinners, etc.)
sure, I've got some dirt in the paint because I'm not a pro body shop, and my metal working skills were not quite perfect, but overall, the results came out pretty good, and most people don't even notice the flaws until I point them out to them.
**Photobucket sucks**
[Re: 70Cuda383]
#1175278
02/09/12 10:37 AM
02/09/12 10:37 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
so buy good materials, and do the time yourself. .
This may be what I do for good practice. My intention is to do all but the final shooting on my Barracuda when I eventually tear it down. It'd be nice to have one piece to "learn something on" rather than the entire car! (goal being a nice driver paint job, it'll be driven too much to fret about it being "perfect")
I may peck away at the prep work and wait until Summer to shoot anything. My Father-in-Law will be in town and has shot a few trucks, experience with mixing paint, etc...things I've never done before.
Anyone recommend a specific filler to run over a few areas on top? As well as the underside has some light pitting in areas from rust that would benefit from some extra material to work with. Assuming Eastwood is the common place to source DIY materials?
[Re: AdamR]
#1175280
02/09/12 10:47 AM
02/09/12 10:47 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Primer it and start sanding. For small imperfections you can use http://www.eastwood.com/metal-glaze-30oz-pump-bottle.html
Stupid question, but I am assuming priming it with anything that comes out of a general consumer rattle can would be taking steps backwards, yes?
#1175281
02/09/12 10:55 AM
02/09/12 10:55 AM
Challenger 1
Cincinnati, Ohio
Yes imo
I'd checkout the local auto paint store for supplies too. Bondo you can buy anywhere, even hardware stores. My local Car Quest store has everything needed for paint work.
#1175282
02/09/12 11:01 AM
02/09/12 11:01 AM
70Cuda383
Marysville, O-H-I-O
that's what I did. so what if the truck didn't turn out "perfect" it's not a show truck, and since it's one of about 15 million Dakota's on the road, it's never going to be "desirable" either. When guys say "it's all in the prep work" it's true. if you can't get a coat of primer to lay down nice and flat without peeling up from contaminates, or you can see/feel waves, dimples, etc. then keep working on it. you can NOT "fill" imperfections with paint. If I can do it, anybody can! Like I said, this is my first real attempt at doing my own paint/body work. when I bought the truck it did not have fender flares on it, and the passenger fender had some light damage to it. I also had a dent on the low rear corner from a parking lot sign, and then I removed the goofy wing off the bed cover and filled the holes in. then decided to add some "bling" and color matched the mirrors, handles, upper trim on the cab roof, antenna base, and trimmed out the tail lights in body color. I used my cheap, 30 gallon HF air compressor runs on 110v, and really not big enough, but I took breaks while spraying to let the compressor catch up, and borrowed my dad's ancient siphon feed paint gun. (oh yea, and the truck had one of those silly billet fuel cap things that I really didn't care for, so I grabbed a fuel door out of the junk yard and repainted it as well) and after: here's some pics after it's all cleaned up and washed. I think these pics are from about 4 months after I did the paint (note, I also had to paint the fender flares, they came off a silver truck) And here you can see the color matched trim around the tail lights. let those pictures motivate you. like I said, I think they came out fairly decent for a first timer, and I've not had any body work classes or training, just from reading stuff on here, and watching "power block TV" on spike and other similar type shows where they show painters doing their work. Tips: sand it again. block it out again. if you think it's perfect, then do it one more time just to be sure. use guide coats, changing the color of the primer can help to see other imperfections you missed. the color is just that. color. aim for a nice even smooth coverage. clear is for shine. spray it heavier so it flows out, and do a couple of coats, gives you something to work with when it's time to wetsand/buff. my paint above is a metallic paint, so I didn't color sand, I went from sanding primer, wiped it down, shot color, then mixed the clear up so it could "catalyze" while I cleaned the gun, and then shot the clear, waited about 20 minutes and shot the clear again. let it sit a week, then I wet sanded and buffed, and let it sit till carlisle (about 4 weeks) before I washed/waxed it Good luck and Have fun! Oh and buy a mask! fumes are no good!
[Re: Challenger 1]
#1175285
02/09/12 11:10 AM
02/09/12 11:10 AM
70Cuda383
Marysville, O-H-I-O
Yes imo
Yes...but....I did it as you can see in my pics. unless you're using a 2-part epoxy primer/sealer, I think spray bombs are acceptable for spot type repairs like I was doing. It's the same sandable filler primer that you can buy in quarts, so you could either reduce it yourself and spray it, or buy a can already reduced and ready to spray.
but, for doing an entire hood, I would buy a quart of filler primer...maybe 2 if you think you're going to do a lot of sanding to it.
[Re: 70Cuda383]
#1175286
02/09/12 11:16 AM
02/09/12 11:16 AM
70Cuda383
Marysville, O-H-I-O
Things I wish I did differently...
on the bed cover, I shot clear right up to the mask line, and felt that I could sand the line away since there was clear on both sides of it, but after lots and lots of sanding in one spot, I stopped, for fear of burning through the clear. If I had it to do again, I would move the mask line up about a foot, and then "fan" up to it so there's a gradual transition. sure, that gradual transition will leave a lot of orange peel in it, but it'll be a lot easier to sand and buff out, since it's really just new clear over original clear at that point.
I wish I painted my grille too. it had some rock chips in it and is nearly as bad as the bumper was, but I didn't notice it as much until after I painted the bumper.
I wish I started with a new bumper. I kept sanding and sanding on the original paint, and could not get a smooth transition, it kept lifting and flaking, so then I tried using filler primer to fill it in and sand it smooth that way, but then the solvents in the primer were reacting with the bare plastic, and kept wrinkling and lifting. I finally gave up and left it "as-is" because I might just end up with an aftermarket bumper in the future anyway.
[Re: 70Cuda383]
#1175287
02/09/12 11:18 AM
02/09/12 11:18 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Keep in mind that certain primers and paint don't get along and can create problems.If you choose to DIY,go to a supply house to buy ALL your paints and pick thier brains alittle. I am not a bodyman,but I stayed in a holiday inn express once
[Re: hemi-itis]
#1175289
02/09/12 11:21 AM
02/09/12 11:21 AM
Challenger 1
Cincinnati, Ohio
That's what I did years ago, became friends with the paint guy at a local auto paint store. This was before Car Quest came to town. He taught me all I needed to know as far as mixing paint.
[Re: 70Cuda383]
#1175290
02/09/12 11:22 AM
02/09/12 11:22 AM
NewbombTurkk
West Virginia
Do it yourself...you will be surprised at the results you can get.......$500 to paint a hood? I painted the wagon in this picture..backyard job, base/clear, materials were $450....
perfect...NO.....look good...yes........was it $5000...NO! Spraying was the easy part! And we did NO wetsanding or buffing....
[Re: NewbombTurkk]
#1175291
02/09/12 11:24 AM
02/09/12 11:24 AM
NewbombTurkk
West Virginia
Go buy a matching kit....a quart should do it.........
