Re: SB bearing issue
[Re: Burnincircles]
#1175127
02/09/12 08:16 AM
02/09/12 08:16 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
#8 is the only rod fed from the rear main. This is where I would look.
Is your crank crossdrilled to oil the rods from two different holes? Otherwise you are only pressure feeding the oil circuit to #8 half the time. Check the crank and make sure there is no problem in the hole from #5 main to the #8 rod bearing.
Leon
[Re: 40ford]
#1175133
02/11/12 12:06 AM
02/11/12 12:06 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
yep never seen a need for full grove bearings that's why some company's don't even offer them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
