Re: A833 input and mainshaft play- how to tighten up?
[Re: IMGTX]
#1175115
02/09/12 11:28 AM
02/09/12 11:28 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
there is a lot of wobble in those shafts. its normal. remember when installed the driveshaft yoke supports the rear of the mainshaft and the pilot bearing in the rear of the crankshaft supports the input shaft.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: mshred]
#1175116
02/09/12 11:38 AM
02/09/12 11:38 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Main drive pinion ("input shaft") endplay (axially) is strictly related to the condition of its bearing.
Mainshafts, as was noted, will lose a lot of slop when a slipyoke is inserted - assuming the bushing is good!
If you have a 23-spline box, I strongly suggest a swap to a "more balls" (high-load) center bearing.
Be sure the needles in the rear of the MD pinion are fresh, too.
While not directly related to the above, making shims to go behind the countershaft gears's thrust washers, bringing endplay down to the low end of FSM specs, is a big help in lash / slop / noise reduction.
Rick
[Re: Rick_Ehrenberg]
#1175117
02/10/12 09:45 PM
02/10/12 09:45 PM
Posts: 3,429 Toronto
mshred
Toronto
Rick
Good to know that this stuff is normal then
It is a 23 spline box, and that said, what do you mean by swapping to a more balls bearing? by center bearing are you referring to the bearing on the input shaft?
As far as the washers at the countershaft go, thats a good idea as well...im assuming that if I have to make them then none of the 4 speed shops sell them???
#1175118
02/10/12 11:32 PM
02/10/12 11:32 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Rick, what is the bearing part number? Tim Quote:
Rick
[Re: astjp2]
#1175119
02/11/12 08:16 PM
02/11/12 08:16 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
Rick
Give Jamie Passon a call as I believe he stocks the high capacity 307 bearing you are asking about.My Richmond came with those bearings from the factory and they are nice.If you have excessive play on the input then your main shaft could be worn out where the rollers ride ![](/ubbthreads/images/graemlins/Twocents.gif) Is it loose enough to rub the retainer sleeve? Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1175120
02/11/12 10:10 PM
02/11/12 10:10 PM
mshred
Toronto
Rick
I will have to check the mainshaft play to see if it does rub the retainer sleeve...never thought to look at that.
Also, this high load bearing I am assuming is for the input shaft if you are referring to the 307 retainer
[Re: fourgearsavoy]
#1175121
02/12/12 01:12 PM
02/12/12 01:12 PM
mshred
Toronto
Rick
So I pulled the transmission out of the garage today and I wiggled the input shaft, and it seems very very loose inside the retainer. I took a piece of paper, stuck it between the shaft and the bearing retainer, and then wiggled the shaft to try and touch the paper and see if I could pull the paper out- I can't, it will tear inside...but if I wiggle the shaft upwards, I can slide the paper in still, albeit not as far in as when I stuck the paper in first....Hopefully all of what I just said makes sense lol
With that said, what could the problem be? If its just a new input bearing, that would be great. Don't want to have to buy a whole new mainshaft if the surface where the rollers ride is worn
