How long to restore a Cuda?
#1174695
02/08/12 01:17 PM
02/08/12 01:17 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
How long should it take a small but reputable resto shop that has done E bodies before to restore a cuda? I supply money, he supplies labor. Seems like many shops should be happy to have a customer like that these days. Had quite a bit of rust so replaced both quarters, floor, trunk, inner fenders, the rest should be normal stuff. The longest hold up was trying to find fenders. But should have sent components out to be ready. It was painted 2 months ago, so things should be moving on rather quick I would think. I always tress I don't want to rush and have a half job, just want progress. Also if anybody has paid for a restoration lately, If they didn't mind giving a ball park grand total so I know if he's close. Thanks
AAR cuda
71 rag challenger
Re: How long to restore a Cuda?
[Re: 3406pac]
#1174696
02/08/12 06:19 PM
02/08/12 06:19 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Im a little confused, is the car painted, and just needs assembly? if thats the case, provided all of the parts need to be restored still, I could probably get it done in 6 months if working just weekends. thats also if the parts (assuming car has been striped to the shell and painted) have been properly labeled and bagged and also complete (no part hunting) If the car ISN'T painted and still needs sheetmetal work, it all depends on how fast the body guy is.. as I dont do body work. it is a little hard to answer this question, but I think if it was painted already, I could do it in 6 months.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: 3406pac]
#1174698
02/08/12 07:53 PM
02/08/12 07:53 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
The shows on TV can do a full boat resto in a week , shouldn't take longer than that ...
[Re: JohnRR]
#1174700
02/08/12 08:05 PM
02/08/12 08:05 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
if your paying for all to BE done,and it hasen't hurt yet,there not close,quality work comes with $$$$ x $$,ecspecially if your not doing anything yourself,once body is restored,each part must be restored and assembled
[Re: JohnRR]
#1174701
02/08/12 08:38 PM
02/08/12 08:38 PM
Posts: 4,799 ILL
MLR426
ILL
It will take longer John the guy is supplying the money train ![](/ubbthreads/images/graemlins/spank.gif)
logan426
[Re: belv2vert66]
#1174703
02/09/12 04:27 AM
02/09/12 04:27 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The question is, are the other parts going back on the car already finished or do they need restored yet? Doing all the smaller stuff beyond body and paint take just as long.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1174704
02/09/12 12:01 PM
02/09/12 12:01 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
Most of the subassemblies have not been sent out yet. The suspension and drive line are completed. But it is not rolling yet. The interior parts have arrived but nothing installed as of yet. And I did give him a max budget so should not be his cash cow project. Thanks
AAR cuda
71 rag challenger
[Re: 3406pac]
#1174705
02/09/12 01:16 PM
02/09/12 01:16 PM
Posts: 21,508 It's a dry heat
gtx6970
It's a dry heat
I went from a painted , but 'completely' empty shell to a done car - right at about 350 hours. Body was painted, Engine , transmission and rear axle were done when it was brought to me.
I did ALL the remaining component work.
Instrument panel, steering column , Interior, ( seat covers, headliner and vinyl top were subleted out ) Grille, tail light assys, console, Rocker mldgs, etc etc etc. Every wiring harness in it is new ft to rear. What wasn't avail, I made. Electronic ignition is completely hidden. Dynomat installation alone was almost 2 full days. Making the park brake system work with subframe connectors. Fabrication work for the Aftermkt A/C install to make it 100% removal and you would never know it was there. Including making the wiring harness blend in with the car as much as possibile.
[Re: FY1TA]
#1174707
02/09/12 07:53 PM
02/09/12 07:53 PM
gtx6970
It's a dry heat
I did this in 10 months . And i dont get in a hurry anymore .
total hours invested start to finish ?( pm if you prefer) And what condition was it at the beginning?
[Re: domingo]
#1174709
02/11/12 12:21 PM
02/11/12 12:21 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
About 15 years!!!!! If you work full time and had an ex-wife that hated cars and then you divorced her and paid her off etc,, blah blah blah I am finally starting to get my 71 Challenger put together after paint/bodywork done.....
My results are not typical and don't reflect the usual Moparts.com members much higher level of enthusiasm!! TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: domingo]
#1174710
02/11/12 02:10 PM
02/11/12 02:10 PM
gtx6970
It's a dry heat
about 350 man hours with everything on hand is just about right. Probably even less.
Key is to have all things needed handy. Heck I think just 250 hours is possible if you have everything you need handy and ready to install.
I talked to Alan Gallant and he said 150 hours is possibile. AFTER all the components are done, but it's the component stuff that eats time. steering column as an example will vary from 6 to 10 hours.
heater box 30 down to 8 depending on a/c or not.
dash frame is another time bandit. Figure a full day to strip it down to nothing AFTER it's removed from the car I have in the 20-25 hour range in a 1969 B-body dash resto right now and I'n not done.
Like I said earlier, I got the lime green Cuda in as a completely painted BUT completely dis-assembled shell. and I just ck'd I have right at 365 hours start to finish.
I have it back in now to change out the rebuilt steering box for another rebuilt steering box and to fix a few other issues.
Throw in a few 'issues' with repop or reman parts and it gets time consuming faster than you might think.
[Re: gtx6970]
#1174711
02/11/12 02:53 PM
02/11/12 02:53 PM
Posts: 72 NewEngland ( Ma, Ct )
MoparJoeMA
If your figuring a complete car start to finish drive it in the door, strip it, do the normal Qtrs, Inners, trunk floor, Extentions, ect. do the body work the correct way, Paint it and then start restoring the rest of the components..A good shop can do a complete car in 10-14 months. and about 1000-1500 hours plus the cost of the materials parts ect. Its very very hard to put an honest time or price on anything as you really don't know what you have until you get there. I did a 70 challenger R/T and had almost 50 hours in the dash assembly alone because when the car came apart it looked like some one played connect the dots with the wire harness. If you want to do a K member the proper way, Dis assemble- blast- paint- new bushings- rebuild the steering box and detain it correct its about 40 hours to make it show quality.. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 3406pac]
#1174712
02/11/12 03:06 PM
02/11/12 03:06 PM
Posts: 344 PA
noplanb
PA
My "small but reputable resto shop that has done E bodies before" did a couple months worth of work then turned into a world class excuse generator that cost a year on my build. It was finished elsewhere.
Sincere wishes for best of luck with your project. You'll need it.
remember when you said honey, some day that car is gonna look so good in front of our house
