Re: nhra and antifreeze
[Re: dvw]
#1174367
02/11/12 09:05 AM
02/11/12 09:05 AM
Posts: 2,937 A shed in England
Tig
A shed in England
I'm sorta on the fence with this one now. Since I run an all alloy motor, I run anti freeze for it's corrosion inhibiting properties but I'm sure it's a non ethyl glycol based type, that stuff hard to get over here. I'm not even sure if it hasn't been banned from sale. All you guys running iron blocks and aluminium heads have a v8 battery, I'm not sure you'll be best off running de-ionised and/or de-gassed water? Don't use R-O water thats the worst thing you can do, I've worked on renal dialysis machines and that stuff eats steel and aluminium at an alarming rate. The purer the water the more corrosive it is. HTH's ![](/ubbthreads/images/graemlins/Twocents.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: maximum entropy]
#1174368
02/11/12 10:31 AM
02/11/12 10:31 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
i think the same thing would have happened if it were water. look, i hear a lot of harping about respect- the g.d. car should not leak anything! any leak is a wreck waiting to happen. i see cars at the track with pieces falling off. take care of your [Edited by Moparts - Family Friendly Site - Keep it clean], gentlemen! sheesh.
That's what I was thinking too. First, I'm glad the guy in what looks like a blue camaro was alright. but, if the car in front of him leaked down the track, I don't know that it would matter if it was water, oil, ATF, Antifreeze, gear lube....the results probably would have been the same.
Racing is a risk, and again, if you cannot accept the risk that the track might not be perfect, and that the guy in front of you might have blown a transmission line unknowingly, half way through the run, then maybe it's time to make it a street car again.
Antifreeze doesn't cause crashes. ill maintained equipment causes crashes. negligent drivers cause crashes. and sometimes "flat out bad luck" causes crashes when a hose unexpectedly fails on an otherwise perfect ride.
if someone spills anything on the track and the driver does not know, and the track officials don't see it, nobody's going to know to clean it up, and at which point, it flat out does not matter what it was.
**Photobucket sucks**
[Re: 70Cuda383]
#1174369
02/11/12 10:36 AM
02/11/12 10:36 AM
70Cuda383
Marysville, O-H-I-O
but, what do I know. I'm not a professional racer, so no, I'm not out there every weekend. I go when my schedule and budget allows me
[Re: 70Cuda383]
#1174370
02/11/12 10:49 AM
02/11/12 10:49 AM
Posts: 52 Virginia
moparroad
Virginia
Have you watched an antifreeze cleanup? If it goes down the track, it takes an extended period of time. This is down time and expense! Antifreeze requires an absorbent, dragging and frequently re-prepping [respray costs about $100.00 at our track] if the antifreeze is heavy it sometimes requires burning or scraping! All because you want to play by YOUR rules rather than the track rules! If I come to your work or house can I play by MY rules? SELFISH! race weekly for almost 40 years! Points at 3 weekly tracks & IHRA tech inspector!
[Re: 70Cuda383]
#1174372
02/11/12 12:15 PM
02/11/12 12:15 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
a lot of people still don't get it DOES your track have a street class on race night like every track down here does if so the antifreeze debate is mute point. if there is 1 class running it then the threat is there period.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 70Cuda383]
#1174373
02/11/12 12:18 PM
02/11/12 12:18 PM
Posts: 447 lake charles, la
sc4400
lake charles, la
This right here completely covers the whole question.
The crash of the '69 is truly an unfortunate deal. Using the implied logic, we should no longer have external oil lines, transmission cooler lines, remote oil reservoirs, the list goes on endlessly.
I've been to at least 25 different tracks. 50 NHRA national events, 100+ divisionals, and never once have I heard the first word about a "anti-freeze" rule. In all that time, I've caused 2 leak cleanups. A valve cover stud snapped off, and a mist of oil sprayed out. They only knew to even look because of the smoke from the oil on the headers. The other a cooler line blew apart on the starting line, and I liked to turned a complete 360.
Any leak is a bad leak. PERIOD. And racing has a level of risk. I believe 99% of us take this very seriously. Those of you militantly passionate about this issue, I respect that. But each of us that leaves the starting line has to responsibly maintain our ride, and trust that the other racers do to.
This isn't bean bag, or chess. If you don't trust the track, don't leave the starting line.
I'm done with this, because no one is going to change their mind.
Be safe.
RIP ![](/ubbthreads/images/graemlins/beer.gif)
[Re: sc4400]
#1174374
02/11/12 01:05 PM
02/11/12 01:05 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Street car or not,The rules ARE the rules.It really comes down to the tech guys that check our cars before we can race.I admit I have not always been able to pass tech,but they never checked.The tech guys will take you on your WORD when they ask,do you have a trans sheild,nuetral saftey swith,ANTIFREEZE ETC.Most of the time they just look at the tags on the belts & helmut.Some of the rules are stupid,but we still have to abide or try to get them changed and I refer more to certain certifications. ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: hemi-itis]
#1174375
02/11/12 01:25 PM
02/11/12 01:25 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
I run evans coolant in my car which is propylene glycol. I contacted e-town tech to see if I could run there with it in the car. In a response they said that they we're not familiar with it but as long as it does not clean up like anti freeze it should be ok. The stuff will evaporate pretty quick with no film.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: jamesc]
#1174383
02/11/12 11:36 PM
02/11/12 11:36 PM
Posts: 2,408 Ambridge, Pa.
rickraw
Ambridge, Pa.
after reading all the post, the only way to eliminate antifreeze would be upto the track owners. don't know what the percentage of turn aways would be, but they would be losing cash. i myself use antifreeze, street ride. i go out 3-4 times a year, switching it out is a pain. member dap stated he uses evans coolant, going to call them & see if it's easier to clean up. like other members on here, i have some serious coin invested & don't want to cause someone else or myself any problems. we are all taking a risk driving over 130, i see the anti antifreeze posters point. everyone stay safe, seeya.
