Page 1 of 4 1 2 3 4
nhra and antifreeze #1174324
02/07/12 11:31 PM
02/07/12 11:31 PM
Az
HOT IN AZ Offline OP
Az
I know NHRA tracks frown upon using antifreeze in your cooling system at there tracks so I was curious as to what you guys use in your cooling system to prevent corrosion with either aluminum or steel radiators. Thanks for your input. Rick
Re: nhra and antifreeze [Re: HOT IN AZ] #1174325
02/07/12 11:33 PM
02/07/12 11:33 PM
superstreet1896 Offline
water wetter for me
Re: nhra and antifreeze [Re: superstreet1896] #1174326
02/07/12 11:38 PM
02/07/12 11:38 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Purple Ice. But I do run a small amount of coolant in my engine. If you run the red extended life antifreeze and a drop goes on the ground, they think that its transmission fluid.
Brian Dunnigan
Re: nhra and antifreeze [Re: HOT IN AZ] #1174327
02/08/12 05:00 AM
02/08/12 05:00 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I used water and drained mine before I rolled it into the trailer.
This with an aluminum motor.
8.30's @3400 lbs
Re: nhra and antifreeze [Re: HOT IN AZ] #1174328
02/08/12 05:28 AM
02/08/12 05:28 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
distilled water and water wetter
MOPAR OR NO CAR
Re: nhra and antifreeze [Re: '72CudaRacer] #1174329
02/08/12 08:10 AM
02/08/12 08:10 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Brian Dunnigan
Re: nhra and antifreeze [Re: hemigod426] #1174330
02/08/12 08:20 AM
02/08/12 08:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's it. My junk hardly ever hit's 190 and then as soon as I start driving it drops to 170.
Coming soon!!!!
Re: nhra and antifreeze [Re: HOT IN AZ] #1174331
02/08/12 10:00 AM
02/08/12 10:00 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Purple Ice....and an anti-Corrosion inhibitor.. I think Gunk, Lucas, STP and a few others make this...
but NO anti-freeze....I take it you already know the reasons why they wont allow it!..
Re: nhra and antifreeze [Re: smokinwoody] #1174332
02/08/12 05:58 PM
02/08/12 05:58 PM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
I've always been curious about "they don't allow it"? Really? I can't find this rule anywhere. Actually dripped some very GREEN anti-freeze at a national event a few years back. All they cared about was did I have the leak fixed. Compared to synthetic oil, cleaning up antifreeze is not a problem. With 75psi oil in several hoses, and 5-10 psi in the cooling system, I worry about oil before coolant.
It will make NO difference what you have cooling your motor if it leaks and gets under the tires.
RIP
Re: nhra and antifreeze [Re: sc4400] #1174333
02/08/12 06:06 PM
02/08/12 06:06 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
RIP
I'm with you... Its more of a track decision.. Mine has antifreeze in it..
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: nhra and antifreeze [Re: sc4400] #1174334
02/08/12 06:41 PM
02/08/12 06:41 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
But compared to water , it is.
Under the tire is a different issue than cleaning up.
I agree that it doesn't matter what the fluid is at that point.
Then we got your conspiracy theorist angle.......... the coolant manufacturers won't pay contingency and kick back money.
I've run both ........ it depends on the nature of the beast , but street driven cars get anti freeze.
Re: nhra and antifreeze [Re: tubtar] #1174335
02/08/12 06:58 PM
02/08/12 06:58 PM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
Watched a 64 aluminum dodge barrel roll down the track after the guy in front of him broke and dropped antifreeze on the track.
If i see one drop of antifreeze near the starting line everything stops and my brother shuts it down and i start walking the lane on the track
Re: nhra and antifreeze [Re: MCHBOB] #1174336
02/08/12 09:02 PM
02/08/12 09:02 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
if the track runs a street class there are tons of cars going down the track with antifreeze anyway so it really does't matter what you run.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: nhra and antifreeze [Re: dusturbd340W5] #1174337
02/08/12 09:18 PM
02/08/12 09:18 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
You right bro!!
Section 8 Racing We are nuts about racing.
Re: nhra and antifreeze [Re: dusturbd340W5] #1174338
02/08/12 09:19 PM
02/08/12 09:19 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i ran 1 gal antifreeze and the rest (about 3 gal) water. i rusted a block a while back with water and anticrosion assitive.(guess it did not work very well)
Re: nhra and antifreeze [Re: dmking] #1174339
02/08/12 09:44 PM
02/08/12 09:44 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
You guys that think its ok to run antifreeze please stay home and garage race over the internet.If any of you guys ever had a car that had enough power to spin the wheels you would understand the guy in the 8 second car behind you would probly nut you if you spilled antifreeze in his lane. Then the track crew would be next in line and then every racer that has to wait half hour or more to clean up after your junk. Reson water over antifreeze is water will evaporate on a hot track. Leak a mist of antifreeze its not easy to see but it will be like a ice covered road.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: nhra and antifreeze [Re: slippery440] #1174340
02/08/12 10:07 PM
02/08/12 10:07 PM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
When I responded to this subject, I knew it wouldn't be long before this type of "righteous" response was presented.
For the record, my 543 KB block/hat/440-1(cnc345) dragster will run easy 7.40's with 50/50 Prestone.
My 565 S/G roadster will run 8.20's with 50/50 Prestone. Every drag car I've been down the track in since 1978 has had anti-freeze. I'm not hard to spot at D4 events, so be sure to give me a bye run!
We return now to regular programming.
BTW, what are the odds you and I would register here on the same day??Go figure that.
RIP
Re: nhra and antifreeze [Re: slippery440] #1174341
02/08/12 10:30 PM
02/08/12 10:30 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
not trying to be wise or anything, what about all the street car's that race. they all have anitfreeze.
Re: nhra and antifreeze [Re: rickraw] #1174342
02/08/12 11:11 PM
02/08/12 11:11 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I ran rad fluid until one guy in the sportsman class yakked the contents of his cooling system on the burnout box, and I watched the volunteers having to clean it up rather than just wiping it away.
I drive 100 miles to the track with water wetter and well water.
I drain it out in October and use the rad fluid I saved from spring.
Re: nhra and antifreeze [Re: rickraw] #1174343
02/09/12 02:20 AM
02/09/12 02:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That is so true. When ever I go to a test & tune there are tons of street cars there with anti-freeze in them. It does not matter what you say as long as street driven cars can race at the track there will be alot of cars there with anti-freeze in them. Its just the way it is. Ron
Page 1 of 4 1 2 3 4
