wiped lobes or not ? HELP #1174243
02/07/12 10:29 PM
02/07/12 10:29 PM
United States
F. Sadler Offline OP
United States
If a cam has a couple lobes wiped will it make the rockers chatter real bad?Also can it cause a roller lifter to break? :help
Re: wiped lobes or not ? HELP [Re: F. Sadler] #1174244
02/07/12 11:32 PM
02/07/12 11:32 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
A roller cam won't usually "wipe" a lobe. Need more info. Hydraulic roller? Spring pressures, etc.
Re: wiped lobes or not ? HELP [Re: F. Sadler] #1174245
02/07/12 11:35 PM
02/07/12 11:35 PM
Mopar garage
flynbyu7274 Offline
flynbyu7274  Offline
Mopar garage
Yes and yes.could be a dead lifter,wiped lobe,stripped rocker adjuster ....if any of the 3 is like running a bunch of lash...pull the valve covers,rockers and pushrods and pull the lifter out with a magnet and see if its cupped .....
Re: wiped lobes or not ? HELP [Re: flynbyu7274] #1174246
02/07/12 11:59 PM
02/07/12 11:59 PM
United States
United States
It's A 5.9 360 mag. crate motor it has hydraulic rollers,stock rockers,don't know the spring press. I was told it's a 380 hp 400tq. LA front..thanks for the info
