Re: Did I find a SURE GRIP ???
[Re: Butt Ugly]
#117399
09/08/08 07:41 PM
09/08/08 07:41 PM
Posts: 1,475 Ontario, Canada
78D150CLUB
My avatar is a self portrait!!
Ontario, Canada
Looks like everyone is lucky these days. I needed an axle for the truck just before Moparfest. Got what was supposed to be a 3.23 open for $150 complete. Bad news, a 3.55, same as I have now. Good news, a clutch type sure grip. Nice find, Jeff. ![](/ubbthreads/images/graemlins/thumbs.gif)
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
[Re: 78D150CLUB]
#117400
09/08/08 08:14 PM
09/08/08 08:14 PM
Posts: 1,951 Toronto Ontario
Butt Ugly
Toronto Ontario
Sounds like I made out OK. Hundred bucks for the gears and hundred bucks for the rear end to put it in. Have not looked yet, easy enough to take the rear end apart to switch out the pumpkin ??
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
[Re: Butt Ugly]
#117403
09/09/08 08:43 AM
09/09/08 08:43 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
You paid a hundred for the sure grip , the gears themself , the ring gear anyway , looks pretty rusty to me .
![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 68Bullit]
#117405
09/09/08 07:43 PM
09/09/08 07:43 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
Yeah You actually made out very good. I'm gonna take a stab and say you have 3.91's, not sure why, but they just look like 3.91's. Look at the bottom of the case just before the yoke and see what the last three numbers are. If it's a 741 case, and they are in-fact 3.91's, then they'll probably howl some, cos' most do. They are generally fine, they are just known to howl.
from the thickness of that ring gear, I'm gonna say 2.94 or maybe 3.23. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: cornucopia]
#117406
09/09/08 08:49 PM
09/09/08 08:49 PM
Butt Ugly
Toronto Ontario
You guys rock, thanks, the guy said it was a 3:23 open set. I will check out casting numbers and turn the gears to see if the ratio is stamped on the ring gear.
[Re: johnnyrotten]
#117409
09/16/08 04:20 PM
09/16/08 04:20 PM
Butt Ugly
Toronto Ontario
Got around to turning the gears and found it stamped 3:23 Nother question, Very easy to turn one way and VERY hard to turn the other way, Normal???
[Re: Butt Ugly]
#117410
09/16/08 04:26 PM
09/16/08 04:26 PM
JohnRR
NO, again look at the RUST on the gears , I'll bet thats not the only thing that has rust on it .
YMMV
[Re: JohnRR]
#117411
09/16/08 04:55 PM
09/16/08 04:55 PM
Butt Ugly
Toronto Ontario
YMMV
Gears look better in person, actualy very clean. Next question, removed the 5 bolts at the backing plate, should the axle just slide out or am I going to have to bang on it and fight with it?
"VMMV" ??
Thanks Jeff
[Re: 6T6Cuda]
#117414
09/16/08 05:47 PM
09/16/08 05:47 PM
Butt Ugly
Toronto Ontario
Thanks again for all the info guys. I'll go give the axles a tug, don't have the drums to try that neat slide hammer trick.
