waternecks!! #1173739
02/07/12 01:37 AM
02/07/12 01:37 AM
alberta
Publicbottle Offline OP
alberta
Which style waterneck do you prefer?!
Sealed with an Oring??
or
Sealed with gasket style??
Re: waternecks!! [Re: Publicbottle] #1173740
02/07/12 03:48 AM
02/07/12 03:48 AM
Mopar garage
flynbyu7274 Offline
flynbyu7274  Offline
Mopar garage
Cast neck and a gasket .....had chrome and o-ring and leak after leak..my
Re: waternecks!! [Re: flynbyu7274] #1173741
02/07/12 07:56 AM
02/07/12 07:56 AM
IN
ahy Offline
ahy  Offline
IN
Cast iron with gasket or true billlet aluminum with gasket. As posted above, I stay far away from the chrome or any diecast version after fighting warpage and leaks.
Re: waternecks!! [Re: ahy] #1173742
02/07/12 01:02 PM
02/07/12 01:02 PM
cast iron w a gasket. W a fine file can drawfile both surfaces to get em flat (move the file back & forth w your fingertips like your scrubbing clothes on a washboard holding the file flat to the work). rag in pump or manifold inlet to keep filings out
