Rallye wheel air valve length? #1173501
02/06/12 09:23 PM
02/06/12 09:23 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Can someone tell me the correct length of the rubber air valve on 15X7 rallye wheels? Also do they need an extension to clear the trim ring? Thank you.
Re: Rallye wheel air valve length? [Re: sbcjd] #1173502
02/06/12 11:20 PM
02/06/12 11:20 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I can't remember offhand what the stem length is, but they did use a 1/2 extension.
Re: Rallye wheel air valve length? [Re: 70440+6bbl] #1173503
02/07/12 01:52 AM
02/07/12 01:52 AM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Thank you for the information. I just want to make sure when I mount my Goodyears to the wheel I use a long enough stem so the 1/2 inch extension will allow me to add air to the tires when needed without removing the trim rings.
Re: Rallye wheel air valve length? [Re: sbcjd] #1173504
02/07/12 04:02 PM
02/07/12 04:02 PM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
Factory?
Just long enough to be a pain in the butt when you need to put an air chuck on them.
Shawn 70 AAR
Re: Rallye wheel air valve length? [Re: ehbody] #1173505
02/07/12 04:23 PM
02/07/12 04:23 PM
MA
steve70 Offline
steve70  Offline
MA
There are 4 or 5 sets listed on ebay under "mopar valve stem extensions"
1970 Challenger T/A 4 speed
1971 Duster 340 4 speed-2017 MCACN Gold Winner
