Dumb Electrical charging question #1173122
02/06/12 03:28 AM
02/06/12 03:28 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
1971 Plymouth 'Cuda originally 383-4, now 440-6
OK, so I just got my engine running. In the process of overhauling and installing my engine, I bought a new wire harness from Year One. 440-6 electronic ignition harness. I had a Tuff brand single wire alternator that I installed. I am using a stock type voltage regulator on the firewall and just disconected the one on the back of the new alternator. Here is my problem. The harness has connections for a four post balist resistor. I got one down at autozone for a 1975 V8 truck. My alternator is putting out 16-16.5 Volts at the battery and I think it might be due to the wrong balist resistor.
Can anyone confirm this and maybe give me a part number that I can get at Autozone or O'Rielys, somewhere local.
Thanks.
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: Dumb Electrical charging question [Re: TinCuda] #1173123
02/06/12 04:02 AM
02/06/12 04:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Ballast resistor would not change the charging current. When you say single wire alternator, do you mean it only has one field terminal to connect like the 1969 and earlier alternators, or that it only has the battery connection and is internally regulated?
Re: Dumb Electrical charging question [Re: 451Mopar] #1173124
02/06/12 04:46 AM
02/06/12 04:46 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
It is "internally regulated" the voltage regulator is just attached to the back of the alternator.
Either way, amps are off the chart.
Maybe these pictures will help
Re: Dumb Electrical charging question [Re: TinCuda] #1173125
02/06/12 04:47 AM
02/06/12 04:47 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
more pictures
Re: Dumb Electrical charging question [Re: TinCuda] #1173126
02/06/12 04:48 AM
02/06/12 04:48 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
In the interest of full disclosure, A buddy of mine wired it up for me. He told me that 16-16.5 Volts is fine. I am not buying it.
Re: Dumb Electrical charging question [Re: TinCuda] #1173127
02/06/12 04:49 AM
02/06/12 04:49 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
last one
Re: Dumb Electrical charging question [Re: TinCuda] #1173128
02/06/12 05:22 AM
02/06/12 05:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
From that picture it looks like the black and green wires from the internal regulator on the alternator were disconnected, and wires from the new wiring harness were connected?
Make sure the battery is fully charged, it it is low, it may charge at a higher voltage for a few minutes, but 16.5 sounds too high?
I would start by disconnecting both wires from the alternator field connections and make sure the alternator is not charging. Then I think the blue wire should have +12 volts when the key is on. Connect that back up and if the alternator starts charging at 16+ volts, it might indicate the other field connection is shorting to ground. Disconnect the voltage regulator plug at the firewall voltage regulator, and ohm it out to make sure it is not shorted. If it is not shorted, connect it to the alternator field connection. With the key on the two sockets in the voltage regulator should have +12 volts (disconnected from the regulator.) Connect to the regulator and start the car and check the charging voltage.
One last check before replacing the voltage regulator is to run a separate ground wire from the engine to the regulator case in case the VR ground reference is not the same as the engine?
Re: Dumb Electrical charging question [Re: TinCuda] #1173129
02/06/12 11:09 AM
02/06/12 11:09 AM
16+ volts will fry or damage every component that is "on". I'd not run it till we get the circuit figured out
Re: Dumb Electrical charging question [Re: RapidRobert] #1173130
02/06/12 08:24 PM
02/06/12 08:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It sounds like your alternator has the field fully energized. Do you have schematic from the alternator manufacturer? If so I can direct you on how to wire it into the factory harness
Doug
Re: Dumb Electrical charging question [Re: dvw] #1173131
02/06/12 08:31 PM
02/06/12 08:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Never did like single wire alternators myself.
Don't be the exception.
Re: Dumb Electrical charging question [Re: dvw] #1173132
02/07/12 07:26 AM
02/07/12 07:26 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
Doug
Would this help?
http://www.tuffstuffperformance.com/pdf/7530_Chrysler_1-wire.pdf
Re: Dumb Electrical charging question [Re: TinCuda] #1173133
02/07/12 08:21 PM
02/07/12 08:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
When you disconnected the supplied regulator did you re insulate the brush holder nearest the alternator output stud? It states in the alternator instructions this brush must be grounded. If it is still grounded the regulator on the firewall will not regulate the field voltage. With the brush grounded the alternator is in the full output mode. Let me know.
Doug
Re: Dumb Electrical charging question [Re: dvw] #1173134
02/08/12 05:25 AM
02/08/12 05:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Doug
Looks like the regulator on the back of the alternator used the #1 terminal to ground the field and regulator. You need to pull the #1 field brush assembly, and re-install it with the fiber washers to isolate it from the case.
Or you could just hook up the single wire regulator on the back of the alternator, and not use the factory wires?
Re: Dumb Electrical charging question [Re: 451Mopar] #1173135
02/08/12 08:24 AM
02/08/12 08:24 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
Stay away from the little tin-box add-on regulator, it's cheap and will blow up. Get the correct isolated stator alternator, (2 wire), for the vehicle and wire it per the stock wiring diagram with correct regulator. The extreme high end of the voltage range for car operation at 70Amps is 15.6V. We used to test 10A mobile radios at 16.2V but just to make sure they wouldn't blow up. Nominal charge voltage for a 6 cell lead-acid car battery is 14.4V, a normal system shouldn't get much above 15V.
Re: Dumb Electrical charging question [Re: 63stabamatic] #1173136
02/14/12 05:27 AM
02/14/12 05:27 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
Well here is your update:
I bought a new externally regulated alternator.
It works great. 14.2 Volts at the battery.
Re: Dumb Electrical charging question [Re: TinCuda] #1173137
02/14/12 06:52 AM
02/14/12 06:52 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
My first Tuff Stuff alternator was junk. Returned it to Summit and second one was OK. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Dumb Electrical charging question [Re: TinCuda] #1173138
02/14/12 08:23 AM
02/14/12 08:23 AM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
You may not know about the fix yet, but you probably still have the factory wiring problem of the output from the alternator being routed through the firewall then the amp guage and back out through the firewall to charge the batttery.
I'd look into resolving that next.
