Re: Dakota Oil pan in an A-body
[Re: goldmember]
#1172593
02/05/12 05:09 PM
02/05/12 05:09 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
If you have room for a rear sump pan I'd steer clear of the dakota pan. A full size truck pan or aftermarket version would be a better choice.
There are some guys running this pan in Superstock with great success. I have one already on my SS engine. But I can also put my 8qrt Moroso on too. The advantage on the Dakota pan is the rear sump and better ground clearance.........
[Re: 10.90 Racer]
#1172594
02/05/12 05:22 PM
02/05/12 05:22 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I like the oil level as far from the spinning crank as I can get it,the stock Dakota pan has a tiny sump,but in SS I'd assume the pan can be modified?
[Re: goldmember]
#1172595
02/05/12 05:49 PM
02/05/12 05:49 PM
10.90 Racer
super street
super street
Ont. Canada
Yes it can be modified......... but I have heard of guys running into the low 10's with the Dakota pan in SS. I was reluctant about the idea at first, but really considering it now..
I think it will fit my car........
[Re: Aspen7695]
#1172597
02/05/12 06:12 PM
02/05/12 06:12 PM
10.90 Racer
super street
super street
Ont. Canada
It will fit in an A body, but you must modify the center link because it hits the pan. Some people will do the modification for $250.00.
Raul
What do they do to the center link??
[Re: perfmachst]
#1172600
02/06/12 11:16 PM
02/06/12 11:16 PM
10.90 Racer
super street
super street
Ont. Canada
hi, in stock eliminator some cars are using the dakota pan. it will fit, with little work. so far as i hear it's worth a tenth over a stock center sump pan. thedrag link hits on right side, can't turn very sharp.
If the drag link just hits on the right side............ could you not just modify the pan a little???
