Putting a 2003 5.7 Hemi in my '66 Coronet questions
#1171192
02/03/12 04:14 PM
02/03/12 04:14 PM
Posts: 287 Iowa, US
oldsklharo
Iowa, US
I came across a 2003 5.7 Hemi out of a Ram pickup and want to stuff it in my '66 Coronet 500 Convertible. I'm sure there are some of you out there that have done this to similar cars and have some questions to ask. 1) Are there any firewall clearance issues? 2) Any transmission clearance issues? Have to cut the hump out at all? 3) Obviously have to make a new cross member. How did you build yours? 4) Motor mounts, most likely have to make my own? 5) Where did you put your computer? Any other tips or tricks would be much appreciated Thanks, Mike ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Putting a 2003 5.7 Hemi in my '66 Coronet questions
[Re: 73MagDuster]
#1171200
02/06/12 11:36 AM
02/06/12 11:36 AM
Posts: 287 Iowa, US
oldsklharo
Iowa, US
The throttle position box in the engine compartment was 2003 only. 2004 and up it was integrated into the accelerator pedal.
Very good to know...... I guess I'll start calling around to salvage yards looking for a '03 ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: oldsklharo]
#1171203
02/08/12 12:25 PM
02/08/12 12:25 PM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
Hmmmm, instead of waiting for info on this thread........ is there anyone out there that has done this conversion that is willing to speak with me on the phone? Or any shops out there that are willing to answer questions over the phone?
The link I posted before should answer most questions (the one with the 6.1 in a cuda)
Best guys are Hotwireauto.com (Squire auto), Modern Muscle, S&P performance (hotrodlane.cc), an http://bouchillonperformance.com/
All great folks and very helpful.
-C
[Re: ramman5600]
#1171204
02/08/12 12:48 PM
02/08/12 12:48 PM
Posts: 287 Iowa, US
oldsklharo
Iowa, US
-C
Thanks again for all the links ...... they did answer 90% of my questions but I have questions about the wiring harness's and computers. I have an '03 engine out of a 2500 truck, can I only use an '03 harness because of the throttle position sensing box? Do I only need the ECU and TCU to make it run and shift properly? I see all these guys sell custom harness but I can get an OEM harness for $200 buxs. If I can make the OEM harness work with out a lot of modification I can save myself $500 +
[Re: oldsklharo]
#1171205
02/08/12 12:56 PM
02/08/12 12:56 PM
ramman5600
Michigan, USA
-C
I would talk with Chris at hotwire. He will tell you the real scoop on what you can or should do. Also check over on forbbodiesonly.com and look for posts by johnsparts.
[Re: ramman5600]
#1171206
02/10/12 10:04 AM
02/10/12 10:04 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
I used Bouchillon performance box and wiring, they delvered the 2003 gas pedal box too since I used a 904 trans and needed a kick down set up. I was very happy with the parts, easy to install and really liked the result. http://www.youtube.com/watch?v=7ZA4euk6R0U
Plynouth VIP '67 TT IC EFI
