Re: Worn out hood hinges?
[Re: MoparKansas]
#1170099
02/01/12 05:45 PM
02/01/12 05:45 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Have you tried shooting some white lithium grease on the hinges and springs?
The Imperial had the same problem until I lubed it.
[Re: Challenger 1]
#1170102
02/02/12 06:54 AM
02/02/12 06:54 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
No it usually means there not adjusted right. Raise the rear of the hinge and it'll make the rear of the hood go down, seriously.
RestoRick taught me that. Go to his website and he'll explain. Thanks to Restorick for that. He can rebuild your hinges too if they need it.
I had the same problem with my Cuda, the rear corners of the hood raised up. I could push them down, but as soon as I started driving, they would pop back up again. I started experimenting with the hinges before I painted it two summers ago, and found that if I tipped the hinges a little from back to front by raising the rear and lowering the front of the hinge a little bit, my hood would stay down - I don't even need to push the corners down after shutting it, they go down when the hood is closed, and stay down.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
