Re: Need somehelp with bellhousing runout
[Re: Red383]
#1169825
02/01/12 11:39 AM
02/01/12 11:39 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
If you have not, remove a bolt from the flywheel for the mag base. It has to be solid. As you spin around the full circle take notes more often than 90 degrees. I did it for every "ratchet" movement (as often as I had to back the ratchet up and crank it again), which probably equated to ~10 degrees. Once you have all your numbers, find the largest difference (i.e. your -2 to +8 for example), and then divide that by two.
I was then advised to check the parallel surface between the face of the bellhousing to the face of the flywheel.
In my case I needed to get offset dowel pins and am now at .002 runout. My parallel measurement after shimming is also .002.
I was shooting for under .005 for the runout, but never got any data on what the max is for the parallel measurement so I just got it as close as I can without going too crazy with it.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Red383]
#1169827
02/01/12 01:31 PM
02/01/12 01:31 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
My 2003 Dodge Truck service manual says "maximum acceptable face runout is 0.010 inch"
PS. Is .005 read "five thousanths"?
yes .005 is 5 thou ...
what are you working on ? .010 is a lot of runout if you ask me .
[Re: Red383]
#1169829
02/01/12 03:20 PM
02/01/12 03:20 PM
Crazy68Dart
Canton, Ohio
Seems like the newer transmissions are not allowing for as much runout. I heard anything under .010 from a few people too. But under .005 was achievable with offset dowel pins.
